Old 04-12-2023, 12:19 PM   #1
briandownunda
WTB: vacuum gauge
Hi folks, my 72 cheyenne super did not come with a factory vacuum gauge. Does anyone out there have one they would like to sell?
briandownunda is offline   Reply With Quote
Old 04-12-2023, 03:09 PM   #2
chevmn
Re: WTB: vacuum gauge
Someone may correct me, but to my knowledge none of the pickups came with vacuum guages factory installed. The larger trucks (C50, C60, etc) did, but you can retrofit.
chevmn is offline   Reply With Quote
Old 04-12-2023, 04:09 PM   #3
72ironmike
72ironmike's Avatar
I believe you are correct sir !
72ironmike is offline   Reply With Quote
Old 04-12-2023, 05:21 PM   #4
chevmn
I may have one if you are still interested, and I can remember to look through my stash of gauge parts, and if I have not already sold it....I know I had one that came out of a tach cluster from a larger truck that I built without vacuum guage for a pickup.
Old 04-13-2023, 11:23 AM   #5
pjmoreland
pjmoreland's Avatar
You will need a gauge cluster lens with "VACUUM" printed on it. You will also need a gauge cluster front tin with the opening in it for the vacuum gauge. Member 70ShortFleet may be able to modify yours to work.
https://67-72chevytrucks.com/vboard/...d.php?t=792563
You will also need to drill another hole in your existing oil gauge backing plate to accept the vacuum gauge.
pjmoreland is offline   Reply With Quote
Old 04-13-2023, 02:05 PM   #6
Tmend
Tmend's Avatar
I have a vacuum/oil pressure gauge set I’d sell. I’ll post photo this evening
Some progress is better then no progress
Tmend is offline   Reply With Quote
