Old 04-23-2023, 05:09 PM   #1
So tell me about hydro boost, 1988 K30, pedal just about going to the floor
Brake light is on and the pedal goes to the floor but will still stop the truck, barely. I bought an A/C Delco master cylinder hoping that “might” fix it, no luck.
Are there more components to replace?
I did another M/C earlier today on my K20, no hydro boost, no problems. Bench bled both of em. Have not bled brakes on K30 since I’m by myself.
Old 04-23-2023, 06:23 PM   #2
Dead Parrot
Re: So tell me about hydro boost, 1988 K30, pedal just about going to the floor
Check all four brakes for fluid leaks. If it is going to the floor, sounds like the hydro boost is working fine. A similar issue on my CUCV turned out to be one of the T shaped things on a rear wheel cylinder had came out of place and let all the rear brake fluid leak out. A pair of new rear wheel cylinders + a new T thing fixed the problem. Those T things are a bit of a pain to find. Not included with the wheel cylinder kit.
Dead Parrot is offline   Reply With Quote
Old 04-23-2023, 06:26 PM   #3
Nick_R_23
Nick_R_23's Avatar
If the brake light is coming on, it means the shuttle valve in the proportioning valve is off to one side or the other due to one side of the hydraulic system not building pressure. Your description of symptoms seems to back this up. Either your master cylinder isn’t building pressure on one port, or you have a blockage or air in a line somewhere.
Old 04-23-2023, 07:04 PM   #4
Thanks for the info y’all ! I’ll have to continue next week.
Old 04-23-2023, 09:23 PM   #5
bigdaddy4x4
bigdaddy4x4's Avatar
you may have the wrong master cylinder some of them where the master cylinder piston is there are differences in the hole where the rod from the hydroboost goes in one is deeper than the other i will post a pic the one on the left is for the hydroboost and the one on the right is for a 79k20 with vacum boost
bigdaddy4x4 is offline   Reply With Quote
Old 04-27-2023, 09:37 AM   #6
v30crewcab
v30crewcab's Avatar
reset your proportioning valve first. get the light off then fix the leak that caused it to uncenter. you got a leak at the front or the rear.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-28-2023, 01:20 PM   #7
mongocanfly
Post Whore
mongocanfly's Avatar
youll need the little centering tool, to keep the prop valve centered while bleeding the brakes
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-29-2023, 06:41 AM   #8
Thanks for the great info, hopefully next week I’ll have time to pull the wheels off, I suspect the rear wheel cylinder(s)
Old 05-02-2023, 01:09 PM   #9
1774btcrew
1774btcrew's Avatar
I literally went through the same issue at the same time on my c30. I lost the brakes about 10 miles from home. Limped it back at a low speed and once I could use neighborhoods, I used the e brake(1 hand on the handle, foot on the ebrake) Had a NOS d
Delco master cylinder for it. My original master cylinder was leaking. Bench bled and installed. Install was easy and took just a few minutes. I couldn't get them to bleed at all. Tried gravity bleeding first, then had my wife pump brakes for me. All to no avail. I went to my shop and grabbed my vacuum bleeder pump, had the wife keep Master cylinder full and pumped away. This resolved my issue. This could be done with one person but it is a lot trips from master cyliner to brakes
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-15-2023, 11:17 AM   #10
Been so busy I’ve not had time to even look at the “Hero” truck, as we call him.
Thanks again for all the good info shared
