04-30-2023, 04:12 PM | #1 |
Steering wheel
My 1965 C10 has the original standard steering wheel. I would like to find an exact copy but in a smaller diameter. Does anybody make such a thing? I do have power steering so I can use a smaller diameter. Maybe there is sometime available that is close? Thanks in advance.
Hairball |
05-01-2023, 12:41 AM | #2 |
Re: Steering wheel
I wanted the same thing for my 62. I looked into having the original cut down but the starting price was $450.00. I couldn't bring myself to spend that. I now have an aftermarket steering wheel.
05-01-2023, 10:09 AM | #3 |
Re: Steering wheel
I don't know of a smaller wheel that's identical, about the closest you're going to find is a 65-66 Chevy Impala steering wheel. They're about 16-1/2" in diameter and are being reproduced and I think are a better looking wheel.
05-01-2023, 11:06 AM | #4 |
Re: Steering wheel
I've modified a few wheels by cutting the rim off, grinding back the plastic to the steel inner frame, and grafting on a donor rim from a random 15" wheel found on ebay, junkyards, etc. After welding the steel cores together, I use PC7 epoxy to build up the missing areas, cracks are ground out to the steel core and filled in, then primed with SPI epoxy (sticks to plastic and works as a high build all in one), then wetsand and paint it with single stage urethane.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
05-01-2023, 12:25 PM | #5 |
Re: Steering wheel
This is great, this is fantastic work.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
05-01-2023, 01:06 PM | #6 |
Re: Steering wheel
The cut down method is the only way to get an original look, many have done it successfully. Do some research on here, I think there is a thread on this topic.
05-01-2023, 07:49 PM | #7 |
Re: Steering wheel
That looks great. I might have to experiment with my wheel. Thanks for showing your technique.
05-01-2023, 08:01 PM | #8 |
Re: Steering wheel
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-04-2023, 05:51 PM | #9 |
It's Better With Nitro
Re: Steering wheel
This is how I've done a few for my projects, including the steering wheel in my current 63 C10. I did this one at the beginning of the pandemic since I was stuck at home. This one went to a customer in AZ.
05-04-2023, 06:49 PM | #10 |
Re: Steering wheel
Vin,
It appears that there is enough flex in the plastic on the rim that it didn't crack much when you re-bent it to the smaller diameter. Did you do anything special other than bent and weld? |
05-05-2023, 09:28 AM | #11 | |
Re: Steering wheel
Would you happen to remember the donor vehicle wheel you used on these exact photos? |
05-05-2023, 01:44 PM | #12 |
Re: Steering wheel
05-05-2023, 02:10 PM | #13 |
Re: Steering wheel
The 15" DONOR rim from ebay, junkyards, etc. used to make the finished product is what I'm asking about. Apologies if that wasn't clear.
"donor rim from a random 15" wheel found on ebay, junkyards, etc." Last edited by verdell; 05-05-2023 at 02:15 PM. |
