05-14-2023, 09:24 PM | #1 |
Block ident and missing numbers
Are there always numbers on the block in front of the passenger side head? I can't see any evidence of any
I finished the engine disassembly this afternoon, the pistons don't have any oversize marks, I need some better tools to check for sure if it's been bored , but with a caliper it's pretty much 4.000". Wondering if the block has been ground. 3970010 block , K 7 date code? I thought it was supposed to be more digits. It's a four bolt main block. It's been somewhat apart before .. lots of timing gear plastic teeth left in the pan..
1971 GMC C25 with a 'refreshed' 1996 Vortec 350/SM465 |
05-14-2023, 09:37 PM | #2 |
Re: Block ident and missing numbers
Those pad numbers & letters are usually shaved off when the block is decked.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-14-2023, 09:47 PM | #3 |
I guess I thought it was weird that it would have been decked , but had standard pistons. Maybe not.
05-14-2023, 09:41 PM | #4 |
K7 is not the date code. Usually they have screw impressions where the date code is...
black one is a more modern block. Notice the flat head screw Last edited by Warrens69GMC; 05-14-2023 at 09:53 PM. |
05-14-2023, 09:48 PM | #5 |
Thanks , I'll have a better look when I get it cleaned up
05-14-2023, 10:08 PM | #6 |
68 C10 Longbed
That’s a good block if it’s in good shape.
05-14-2023, 10:09 PM | #7 |
68 C10 Longbed
That 010 block is a good block if it’s in good shape.
05-14-2023, 10:10 PM | #8 |
05-14-2023, 10:27 PM | #9 |
How about C 23 ? Right side of block
05-14-2023, 10:36 PM | #10 |
I think that means second week in March 1973
05-15-2023, 11:32 AM | #11 |
05-14-2023, 10:39 PM | #12 |
Copied from the internet;
Small Block Chevy BLOCK # 3970010 Engine Block Casting Numbers This is probably the most common 4" bore SBC Block cast. It has been used in many different applications. Only way I know to be sure of 2 or 4 bolt mains is to pull pan.SBC BLOCK # 3970010 Engine Block Casting Numbers This is probably the most common 4" bore SBC Block cast. It has been used in many different applications. Only way I know to be sure of 2 or 4 bolt mains is to pull pan. I have had or machined many of these and they have a good nickel and tin content. I would take as many of these as I could afford just to keep on hand. The 010's have always been considered to be a good block to use. Your block was used probably about as much as any Chevy block ever was used from April or May 69' through 75'. It came in 2 & 4 bolt mains and was used extensively in trucks. Also in Corvette, Camaro, Chevelle, Nova, Monte Carlo's and pass. Look at your oil filter housing and see if there is an 010 020 This will tell you that the block was made with an extra 1 percent tin and 2 percent nickel content. That means it's very desirable for a performance. Block. They have a good nickel and tin content. I would take as many of these as I could afford just to keep on hand. The 010's have always been considered to be a good block to use. Your block was used probably about as much as any Chevy block ever was used from April or May 69' through 75'. It came in 2 & 4 bolt mains and was used extensively in trucks. Also in Corvette, Camaro, Chevelle, Nova, Monte Carlo's and pass. Cars. Look at your oil filter housing and see if there is a 010 or 020 stamped there. This will tell you that the block was made with an extra 1 percent tin and 2 percent nickel content. That means it's very desirable for a performance block. |
05-14-2023, 10:57 PM | #13 |
Who Changed This?
As for timing gear plastic, piece-work mechanics don't generally remove the pan and clear the pan and oil pick-up screen of the pieces. I've seen some pretty clogged screens. I'm guilty of it, myself. It just depends on how much of the gear teeth are missing, so it's a judgment call.
05-15-2023, 12:00 PM | #14 | |
I don't know, but I think it sat for about 30 years, truck had 1984 plates on it.
06-13-2023, 03:07 PM | #15 |
I sold that block to a guy who builds engines, he found the numbers on the bottom of the block once it was cleaned up. They were on the pad where the starter would mount on some engines, the starter was mounted to the bell housing on that one.
Was a 71 code, probably original to the truck. He hadn't seen the numbers in that location before
