05-22-2023, 12:44 AM | #1 |
Parking Break Rear Cable Help.
Swapping out the 8-lug 3/4 ton rear end for a 5-lug 1/2 rear end. Can I use the stock rear parking brake cables from the 3/4 ton brakes on the 1/2 brakes? I have the cables from my original rear end. The 1/2 rear end didn't come with any so trying to use what I already have.
Putting 1971 C10 1/2T 5-lug rear end in a 1969 C20 3/4T Suburban. (I tried looking up park numbers to compare the two but can't find a part number for my suburban) |
05-22-2023, 06:31 PM | #2 |
Re: Parking Break Rear Cable Help.
Still looking for help with this?
05-22-2023, 09:50 PM | #3 |
Location: Herculaneum MO (20 minutes south of St. Louis
No you will have to get the cables for the 1/2 ton rearend
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
05-22-2023, 11:35 PM | #4 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Here's what your looking for... https://www.classicparts.com/1966-72...ctinfo/71-771/ And here's LMC's image of the various parts of the E-brake cables... https://www.lmctruck.com/1967-72-che...g-brake-cables
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-23-2023, 12:42 PM | #5 |
Post Whore
I don't believe you can as the 3/4 ton axle has different sized drums and backing plates so the inter-cable is likely a different length.
I don't believe there any difference in a regular long bed pickup and a Burban part numbers for the rear cables as I don't remember having any problems getting new ones for mine though NAPA back in 2017. Just be sure the person behind the counter understands which springs you have. They may have to look in the book () if their computer doesn't tell them which is which.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-25-2023, 12:43 AM | #6 | |
05-25-2023, 12:52 AM | #7 |
https://www.inlinetube.com/ may have the parts / info you need
for an axle swap you may have to call if search doesn't turn up something obvious good luck!
I started out with nothing - and I still have most of it |
05-26-2023, 05:23 PM | #8 | |
Post Whore
05-26-2023, 11:02 PM | #9 |
05-27-2023, 04:09 PM | #10 |
It's been several years (2017) since i replaced the rear cables on my 1/2 ton SWB.. If I remember correctly, the front rear cables are the same for all 1/2 tons with coil springs - SWB, LWB, and Suburbans. The intermediate cable is determined by the wheel base.
05-27-2023, 11:41 PM | #11 | |
I suppose the front cable might be different for the earlier hand lever vs the later pedal type.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
