Old 05-22-2023, 05:05 PM   #1
kglowacky
blower motor specs
does anyone make a high-performance blower motor for my 78 c-10? I would like a little more airflow coming out of the s/c vents.
kglowacky is offline   Reply With Quote
Old 05-22-2023, 06:23 PM   #2
Loco83
Loco83's Avatar
Re: blower motor specs
I replaced my blower motor with one out of a 91 and it puts out some good air.
Loco83 is offline   Reply With Quote
Old 05-25-2023, 08:45 PM   #3
Pontiac1976
Pontiac1976's Avatar
Loco83:
As said should work.
But you have A/c system then you will not get much improvement, But None A/c system you can buy a A/c motor ( but you want the motor to have a threaded end with a nut or a flat spring nut clip so you can take off the A/c long cage and put on a new None A/c cage ( or your old short cage ) The motor should have steel magnets around the motor housing that the higher output motors.) " Do not buy the cheap molded cage to the shaft of the motor" Because the A/c motor will not fit the none A/c housing.
You can go to 1one of the pick your own part yards GM cars 83-93
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
