06-11-2023, 04:46 PM | #1 |
Active Member
Speedometer gear ratio adapter lubricant?
I finally got my truck on the road and diagnosing a non-working speedo. As part of the troubleshooting, I removed the rear ratio adapter and when trying to manually rotate, it was very stiff. So I removed what appeared to be a plug on side and noticed a lot of hardened grease in the gear housing.
That freed up the sticking and it rotates very smooth. Does anyone know what type of lube is used? I assume it is some type of grease as oil would leak out around both connections like it did while I was flushing it out? Adapter p/n 1563872 along with a couple photos. Thanks for any help! |
06-12-2023, 02:53 PM | #2 |
Re: Speedometer gear ratio adapter lubricant?
I'd go with white lithium. As per my Google assistant.... It is a corrosion-resistant lithium grease for metal-to-metal, metal-to-plastic, and plastic-to-plastic applications. Primarily, white lithium grease is used to lubricate moving parts, such as 3D printer mechanisms, gears, spindles, hinges, latches, tracks, pulleys, cables, machinery, tools, and equipment.
06-13-2023, 07:31 AM | #3 |
Active Member
Thanks as lithium seems like a perfect fit for this application.
