Parking brake questions for my ‘64.
Guys, I’m curious what most people do when they run a TH350/400 in one these. I have a tubular transmission mount installed and need to redo the parking brake as the original setup is no longer an option. I believe I need to convert to a 66+ setup but I’m sure some of you have crossed this bridge already. Thoughts? Also, if anyone has a complete kit I can purchase please let me know. Thanks, Bob.
![]() ![]() ![]() Join Date: Jan 2018
Re: Parking brake questions for my ‘64.
Most people convert to the 66 parts. I believe all the typical repop parts sellers have the parts you need
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Hi.
Some pics i have saved on phone. Hope it helps. Pics came from web search. Cheers. Adriaan. |
The transmission cross brace came flipped and bare when she was purchased, so I bought e-brake components and bolted them on. Has worked without any problems for the last 10 years.
My truck ain't dead, it just smells funny. |
Moderator
![]() Join Date: Dec 2012
My 65 had all the parking brake components removed. Everything from the handle to the lever part in the drums. Cables were cut off. So... I pieced it all back together, with a mix of used parts and new cables. Works perfectly.
