06-29-2023, 09:46 PM | #1 |
1963 K20 Parking Brake Help!
It's time to get my parking brake sorted out but I can't find a diagram for this year and model that's anywhere close to what I have.
How do I go about measuring the two lines from the linkage to the drums to make sure I'm ordering the correct part? Also, the line from the steering column to the linkage was also cut. Any idea how to measure this and find a replacement? |
07-01-2023, 08:56 AM | #2 |
Re: 1963 K20 Parking Brake Help!
I can help you out with that but won't be home to measure mine for a week and a half.
07-01-2023, 09:38 PM | #3 |
07-02-2023, 10:14 AM | #4 |
The front cable P/N 2405083 89 35/64” OL 1st ser.
Look through the cable section to find the rear cables. http://www.gmpartswiki.com/getpage?pageid=22352 Last edited by gmc jr van; 07-02-2023 at 10:35 AM. |
07-04-2023, 06:52 AM | #5 |
Inlinetube.com seems to sell all the cables. They look correct to me. I have a 62 K-20.
07-11-2023, 06:01 PM | #6 |
A few years ago I wrote up a DIY about converting park brakes to the style used in 1966-1972 C10 trucks. It may or may not be used in the 4X4 trucks.
These ideas might be helpful. Link here. https://lugnutz65chevystepside.weebl...-1972-c10.html
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
07-12-2023, 10:45 AM | #7 |
First you have to determine if its a 1st series or 2cnd series because its a 63. They had different frames in 63 as the 4x4 frames were a change over mid production year for 63s. Also always mention Chevy VS GMC when asking ? as GMC is different . I was able to find a previous post of your 63 Chevy with 292 K20 which makes it a second series being a 292.
GM Part number for a 1963 2cnd series FRONT cable 4x4 3824111 is 85 11/16 long and just so happens to be listed on ebay https://www.ebay.com/itm/36434397653...Bk9SR96Y_NaoYg GM Part number for 1963 2cnd series REAR cable 4x4 3824114 GM parts book does not give a length but its for ALL Chevrolet 1963-1966 K20 4x4
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-17-2023, 11:00 PM | #8 |
Thanks for all the info. Now that I have the cables in hand, and roughly laid out to verify length, I need to work on taking apart the axles. Does anyone know what axle nut I need for a HO52 and what seal I need when reinstalling it?
07-29-2023, 10:17 PM | #9 |
Now that I've got everything disassembled, I'm running into a problem with the part noted below. On the old one I took out, the flanges are together. The new part there's a big gap and I can't get them to close. Does this look right and I'm just doing something wrong, or should I contact the parts dealer?
