Old 07-01-2023, 09:28 PM   #1
v30crewcab
v30crewcab's Avatar
frame rivet length
anyone know what length of rivet to use on a 1 ton frame? got a few that need fixed and I'm not interested in bolting it. I want to hot rivet them like original. Its just a bare frame and I can get to it easy. thanks.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-02-2023, 08:51 AM   #2
rick1956
rick1956's Avatar
Re: frame rivet length
When I worked at Boeing, the general rule was to make the rivet protrude as far as the rivet diameter measures. Of course, that was aluminum, but I'm pretty sure the general rule is still applicable.
So basically, a 3/8 rivet should protrude 3/8" out the backside before your bucking bar mate applies his support.
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 07-02-2023, 08:56 AM   #3
v30crewcab
v30crewcab's Avatar
thats good info. thanks.
71 longbed 5.3 4l80
Old 07-02-2023, 10:13 PM   #4
kipps
Take a couple photos of the process, and post them in this thread. I'd be interested to see how hot riveting is done on a hobbyist scale.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 07-03-2023, 06:39 PM   #5
v30crewcab
v30crewcab's Avatar
I'll try to remember. may be awhile before it get it done.
planning on heating them with a torch and punching them in with an air hammer attachment.
71 longbed 5.3 4l80
Old 07-07-2023, 05:35 PM   #6
rick1956
rick1956's Avatar
One other thing that just occurred to me I forgot to mention: That rivet length "rule" is very much dependent on the fit of the rivet in the hole. Since the whole idea of riveting is to have them swell to fill the hole they're put in, it needs to be an accurate fit to keep the rivet tail from being too thin when you're bucking it.
Old 07-07-2023, 05:43 PM   #7
Keith Seymore
Keith Seymore's Avatar
Original was not hot; they were cold riveted.
Also - the factory repair for a missing or mis hit rivet was a 3/8 grade 8 bolt.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
