![]() Join Date: May 2004
Which Carb Spacer/Insulator?
Looking to address a vapor lock issue so my chief goal is insulation. I want to insulate my Edelbrock 1406 but am not sure which spacer/insulator to use. It sits on an Edelbrock 2104 intake manifold. Looks like I've got room for 1/2 inch clearance without nay trouble. There seem to be several candidates: the Edelbrock 9266 Heat Insulator Gasket, the Edelbrock 8725 Carburetor Spacer or maybe even the
Edelbrock 9265 Square-Bore Heat Insulator. Perhaps one not mentioned here? What say you? Thanks
Re: Which Carb Spacer/Insulator?
My goal was to reduce the temp of my throttle body and hopefully solve some idle quality issues by increasing plenum size and distance from injectors to runner. Went with this one from Summit: https://www.summitracing.com/parts/sum-g1408 Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Apparently, whether or not the spacer is divided, has minimal impact on performance?
I use this. It requires no gaskets too but some have had issues with the metal ferrules. Just be sure there not proud.
https://www.summitracing.com/parts/edl-9266 |
#5 | |
https://www.motortrend.com/how-to/pi...t-performance/ -klb
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Any Phenolic spacer at least 1/2" thick will help and a 1" thick would help even more. I'd go with the open design to equalize the vacuum on all four barrels of the square bore carb on a spread bore dual plane intake. If you had a Holley 4 corner adjustable carb then a separated or 4 hole spacer would allow fine tuning the four corners. Solid plastic is ok, the composite phenolic spacers insulate the best, they're a bit more expensive but resist heat warpage better than solid plastic. https://www.summitracing.com/parts/sum-g1405?rrec=true I always spray the gaskets with WD-40 before installing them, makes them come loose easier.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Some great and sound advice from Ironangel!
I installed a 1" composite phenolic spacer on a 454/Edelbrock/Edelbrock setup for the same reason over a year ago, to reduce heat on carb from the intake and it has worked well/served me well ever since. Driven hard on a daily basis.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
Whichever you choose you will need new longer manifold/carb studs to match.
Going with the 8725. Any idea what the torque might be on that? I'd hate to get too aggressive and crack it. Thanks for the the replys.
#10 | |
![]() Join Date: Jul 2000
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
I just had to put one on my 71 k10 that has a new Edelbrock 1406. I needed one that was .5" because 1" would have been too tall. I went with the Trans Dapt pt#2180 So far, it has 100% fixed the usual Edelbrock fuel bowl boiling issue.
1970 SWB Build |
#13 |
I just thought of this: Be prepared for potential issues with throttle rod, detent cable, and hard fuel line if you mount the carb too high. I once had that issue with a 1" spacer. However, the taller ones may work even better than the .320" Edelbrock that I mentioned above.
Carter had the right idea with the ThermoQuad that used a phenolic resin main body. And, of course, Holleys don't have the problem. I had an 82 C10 with a mild 350 that ran a basic 80457SA (Shiny Aluminum) 600cfm Holley that didn't even use a spacer, and it never had a fuel-boiling issue, even in hot Texas summers. Alert! This not a Edelbrock/Holley pi$$ing contest!
#14 |
I’m thinking the 68 needs one truck runs great when it’s cool out but once it gets hot it has a slight flooding feeling at light throttle . Also the fear bumper gets a little soot on it . Doesn’t happen all the time just when it’s very warm out . I use Non ethanol high test in it too .
#15 | |
#16 |
If you have divorced choke keep that in mind.
#17 | |
https://www.sonnax.com/parts/2767-ca...-corrector-kit They are also available for Holley carbs, and Holley clones. ![]() Here's one that I used on a dual quad setup. Yes, throttle cable needs slight adjustment. ![]()
#18 |
![]() Join Date: Nov 2008
A lot of times it is the fuel getting heated up in the fuel line. It is normally run close to the block. DEI offers some products for this.
I run an open 1" spacer with a Holley carb and would definitely go to a 4 hole set up next time to improve carb signal.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#19 |
I've heard that before. I have some DEI heat shroud that closes with Velcro, and I think it's a large enough diameter to fit over my lines and filter that sit 1"-2" above the manifold. Even with a spacer, I sometimes find myself cranking over the engine for too long.
#20 |
The other issue that significantly contributes is not having a return line. A return line as close to the carb inlet as possible, will keep fresh, cooler fuel constantly circulating. Obviously adding a return line isn't the easiest option, though
#21 |
I went through this fuel boiling saga a couple of years ago. I ran cool water onto the fuel pump and the hard line to the original Quadrajet. No change but when I cooled the carburetor (I tried two) the rough idle settled down. I was intent on switching to Sniper but I tried a Holley 4360 I had laying around and the problem went away. Quadrajets don't seem to like that cast-iron skillet.
#22 |
OP
for your manifold and Eddy 1406, use the Edelbrock 9266 heat gasket |
#23 | |
#24 |
I did manage to insulate the fuel line & filter from pump to carb with aluminum wrapped fiberglass. I haven't installed the spacer yet. The problem is fairly reproducible- Hot weather, hitch up the boat, no overdrive, hit the freeway, come to a stoplight after exiting- STUMBLE! STUMBLE!, recover. Maybe I'll make a run up to the lake and see if there's any improvement.
#25 | |
