07-18-2023, 02:27 PM | #1 |
I'm flumoxed
Hey Folks,
it's been a long time for me,.... lost my '71 C10 Cheyenne Super in an accident and sorta quit for a while. (Should have stayed "quit"). I bought a '63 C10 long bed stepside from a collector/dealer of sorts. If he could have, he'd have lied about how much air pressure was in the tires. Anyway, I'm now in the throes of trying my best to get this "steed" back to reliability and roadability. Both are a challenge and expensive. Here's my dilemna: Living in southwest Florida, the outside temps as in most of the USA are sky high. Suddenly with the A/C on, the temps immediately go to 220 and stay there. At idle and even driving at 45-60 would not bring the temps down. As soon as I turned off the A/C temps came back to 190. So I changed out the fan. Installed a Flex-a-Lite 3000cfm and cut 6 3" holes into the shroud with "flappers". This helped the temps, but the puzzling thing is that at road speeds 45-70 MPH, the temps slide up to 210-215 from 190 (A/C is on). Then when back in stop and go driving, the temps fall back to 190 or so, (A/C still on). I currently have merely a single core. Trying one fix at a time. It seems the new fan gives me better temps, but I cannot understand why highway driving raises the temps and stop and go brings the temps back to "Normal"). Obviously there are no hills,.. it is flat Florida Anyone got any thoughts/help? Thanks. Jack |
07-18-2023, 07:52 PM | #2 |
Re: I'm flumoxed
I would try a small drive with your bypass flaps taped shut or maybe do one side at a time. you might be bypassing the fan too much at speed so while the air from grille is cooling truck the fan isn't helping it along. I haven't had great luck with aftermarket fans\shrouds so I usually scavenge something from a newer vehicle at junkyard that fits decent and go from there.
07-18-2023, 08:21 PM | #3 |
Re: I'm flumoxed
What do you have for a fan shroud?
Do you have pics of it and your engine bay? |
07-19-2023, 12:18 AM | #4 |
Re: I'm flumoxed
Would be good to see a pic. I had a trans cooler in front of my radiator and and heating problems. I ended up moving it to under the passenger floor with a strong fan extracting the hot air from it and it fixed my overheating dramas.
So perhaps have a feel for how hot the condenser is getting? |
07-19-2023, 09:54 AM | #5 | |
Re: I'm flumoxed
Thanks Jack |
07-19-2023, 10:32 AM | #6 | |
Re: I'm flumoxed
Thanks Jack |
07-19-2023, 10:35 AM | #7 | |
Re: I'm flumoxed
Thanks Jack |
07-19-2023, 10:45 AM | #8 |
Re: I'm flumoxed
Could be your shroud is blocking enough air at higher speeds to make the temp climb.
Try removing it and see if that helps. |
07-19-2023, 12:55 PM | #9 |
Re: I'm flumoxed
Just some food for thought, how clean is the core on inside, i had a case once where tubes were blocked internally and did the same thing.
In town all good but freeway driving it kept climbing. |
07-20-2023, 09:15 AM | #10 | |
Re: I'm flumoxed
https://www.chevelles.com/threads/co...1160281/page-3 |
07-20-2023, 11:19 AM | #11 |
Check The Champ, Demonstrator
Re: I'm flumoxed
Are you running the Chevrolet Cool Pack as an A/C unit ?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-20-2023, 10:42 PM | #12 |
Re: I'm flumoxed
If you mean "single core" you are referring to the radiator size you need much more radiator. Get an aluminum radiator with a thick core.
George |
07-21-2023, 12:26 AM | #13 |
Re: I'm flumoxed
When you say immediately, do you mean like right-freaking-immediately, as in: there is no way the engine could actually be heating up that freaking fast?
If so - Is it an electric temperature gauge? Could be a resistance issue with the A/C being on, messing with the gauge.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
07-21-2023, 10:04 AM | #14 |
Re: I'm flumoxed
Fans have not been installed backwards by any chance. That happens.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
