09-15-2023, 02:52 AM | #1 |
Headlights flicker and radio cuts out when going over bumps
Hi all, I wanted to stop by and ask about an electrical gremlin I'm having in my truck. It's an 87 model with the Tbi 350 and 700r4 transmission, 2WD. Every time I go over a bump, the headlights seem to flicker a bit, and the radio cuts out.
It's a modern radio so when it loses power it restarts, which takes a few seconds. And that should help with finding the problem. Cause you'd just wiggle stuff until you hear the radio cut out. But despite all the wiggling and jiggling of wires under the hood, I can't make the radio cut out while the truck is in my garage. For some reason, it wants to go over a bump in the road before it will reproduce the problem. So I must be doing it wrong. Is there someplace else I should check? I've recently checked all the grounds because I had to replace one to get the starter to work. So I know the main ground to the frame is good, and so is the one that is on top of the engine. If anyone knows of other more obscure ground wire connections, I'll check those too. Thank you |
09-15-2023, 03:11 AM | #2 |
Re: Headlights flicker and radio cuts out when going over bumps
Most likely a Gound to the radio @ the dash or connector to the radio wire lose or not connected all the way it properly. If that check out ok, work your way back to the fuse box good luck
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-15-2023, 03:15 AM | #3 |
head lights Check the ground to the left of the head light by the piler grounds work way back to the switch to the fuse box
09-15-2023, 03:16 AM | #4 |
But why would the radio ground make the headlights flicker? I could understand if only the radio cut out when going over a bump. But the headlights flicker at the same time.
09-15-2023, 07:28 AM | #5 |
It sounds like one of the grounds on the core support
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-15-2023, 10:34 AM | #6 |
Also check for corrosion where the harness connects to the fuse block on the firewall.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
09-15-2023, 02:00 PM | #7 |
Pull and reset the fuses for both radio and headlights. Simple to do and there might be bump sensitive corrosion on the press fit connectors.
Possible the headlight wires have a damaged spot in the wiring harness caused by years of rubbing on something sharp during bumps. Hit a bump, brief short, quick voltage drop, radio resets. Might not even be the headlight wires. A similar type short in the rear lighting wires might cause it. Any trailer hitch light harnesses? Those often involve cheap crimp connectors that corrode over time. Or the tape comes loose. |
09-15-2023, 08:28 PM | #8 |
Thanks to all, I will check these suggestions tonight.
I did recently replace the starter. Is there any possibility that the starter wiring could have an effect on the radio and headlights? |
09-16-2023, 01:39 AM | #9 |
Yes on starter wiring. The main supply for the junction box often comes off the starter. If the nut has come loose, could cause your 'bump' problem.
09-16-2023, 09:10 PM | #10 |
Radio Problem was first Ground most like maybe a power lead loose! Radio aftermarket, Is the radio got its own ground green/or Black wire to the dash brace support is it a good connection. If it ground through the radio case, is it snug not loose as hard bump hit make it re-boot for both conditions.
Now since you said you checked the grounds at the front guessing you checked the rad support head light and light grounds and they were, ok? since you said you had both radio and headlight flicker. The short is most like in the cab area since radio from the fuse box to the dash body ground. As I said or there is brief short + side from or at the fuse box + feed. Now Headlights and Radio happen at the same time then for sure it in the cab. Headlights as said buy all other are good place to look. if the headlight first or second start flicker. and the radio some or has all was doing this but not for same time as the headlights. The headlight old to or new as the blub could be shorting out at the filaments (<replace with new headlights) or the connectors to the headlight bulbs inspect and clean all connection, bulb side and plug side ground and the rad support if you did not do that. The headlight switch is bad or the connector or the spring rusted the Ground for the switch a lot of dash electric option is at the left piler @ the about height of the a/c vent or the switch if you do not have a/c vent. Some reason window leaks or drip water on the ground post there. hole in the glass channel. hole in the vent or rust in the outer vent leaking on the fuse box.
09-16-2023, 09:27 PM | #11 | |
I would bet you starer would be running hotter then or would be cutting out not starting now and then. If the starter working easy seeing sparks when starting or it not heating up starter or wires hot to touch start up for 10-15sec. It most likely ok. After turning off a extra hands eyes will help there. At this point you check clean nut and the wire rings.
09-17-2023, 02:34 PM | #12 |
theres two fusable links going up from the starter wire. they are in white or black plastic usually. I've had one of those start losing connection and caused my headlights to be intermittent.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
09-17-2023, 09:40 PM | #13 | |
So I'm going to redo the starter wiring because it looks pretty bad. There's some holes in the insulation, and the factory fusible links (those in-line plastic cylinders) look like they're ready to fall off. So does anyone know why the starter wires are 12 gauge, but the fusible links they connect to are only 14 gauge? I'm kind of an electrical newb but that doesn't seem to make sense. Seems like your fusible links would also need to be 12 gauge. Here's some: https://www.ebay.com/itm/313506742421 |
09-18-2023, 07:32 AM | #14 |
GM fusible links are normally 4 sizes smaller(larger number) then the wire they protect. 12ga wire = 16ga fusible link. The newer OEM links will have the size number stamped into the plastic cylinder. The smaller link wire size lets the link get hot and melt before the main wire. They are a fuse of last resort if something goes wrong with the electrical system.
I have found several good OEM links on later model trucks in the salvage yards. While the wires are routed a bit different, the lengths are pretty a pretty good fit for the earlier trucks. |
09-18-2023, 12:07 PM | #15 |
Is your cab sagging heavily in the front?
My 91 s10 is rusted bad to the point the cab actually was pressing the harness against the back of the block. So I would hit a bump and it would cut the lights, radio etc. Not really a huge deal as they came right back on and it would only do it every now and then. Eventually it cut the truck off then it would go right back to normal a second later with only a "check engine" light illuminating for a second. It would only happen once every 20 days or so though and I figured it was a ground somewhere. I replaced the main bat to engine and ran a new engine to chassis ground and called it good. I kept driving it for short runs etc. That little 2.5 would just go and the thing handled great. Did nothing for like 60 days so I thought I fixed it. I hit a bump and the thing straight up shut off. It would crank but that's it. Towed it back to the house. Upon further inspection I fried the harness back by the head as well as fuse able links off the alternator and pretty sure the ecm or at very least distributor pickup is toast. The truck sits now waiting to be turned into something cool later. So yea if your cab is sagging forward with like 1/2" fender gap at the bottom of the doors maybe you should check the back of the block to see if your harness is being crushed. I went through everything on that truck mechanical wise. But the body was not worth saving and the electrical worked so I left those alone. It will make a great chassis for a hotrod at the very least. But simply running my hand behind the head to do a basic inspection may have had that truck running today. Live and learn.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build Last edited by cerial; 09-18-2023 at 12:16 PM. |
09-20-2023, 01:23 AM | #16 |
Naw not in this case, rust isn't the issue. Texas truck so very little rust, if any.
In TX our interiors get consumed by the sun, but we don't have rust. |
