10-05-2023, 09:08 PM | #1 |
lowering brake pedal 1966 c10
A friend of mine has a 66 c10 with manual drum brakes all the way around. He has had hip replacement and is having trouble getting his foot up to the brake pedal. Is there a way to lower the brake pedal towards the floor about 2 inches?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
10-05-2023, 09:50 PM | #2 |
Re: lowering brake pedal 1966 c10
I will be doing that to my '61 shortly.
I expect to merely shorten the rod to the master, and fabricate some sort of extension to hit the brake light switch and reach the stopper. If there is a stopper. I can't remember. You can't really re-shape the arm itself, as it still has to contour the floor.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
10-05-2023, 10:45 PM | #3 |
Yes, it has been done before by replacing the original rubber bump stops for the pedal with some bolts.
I had planned on doing it with my truck, but haven't got around to doing it yet. https://67-72chevytrucks.com/vboard/...d.php?t=516070
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-06-2023, 07:30 AM | #4 |
Thanks!!!
10-06-2023, 10:43 PM | #5 |
I lowered my brake pedal close to an inch today; whatever was comfortable with the gas pedal I have.
Adjusted the push rod, and there was ample adjustment in the brake light switch. Fabricated a similar stop as to the link above. Thanks!
10-07-2023, 07:31 PM | #6 |
Ok what about going to power brakes. The guy thinks he might want power brakes too. What combo should I get and how hard is this upgrade
10-21-2023, 11:26 AM | #7 |
My suggestion for converting to power brakes would be to get a brake booster adapter bracket from CaptainFab on this board, along with a booster and dual tank master cylinder from a 67-70 C10. The bracket bolts right up to the firewall with no mods and the above booster bolts right to it. Doing it this way also requires splitting the brake line by the right front upper control arm. And this isn't a big deal, either. Do some searches and look in the FAQ section in the 60-66 section. Lots of info on doing this.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
