10-25-2023, 07:31 PM | #1 |
Gmc 351e big block v6
GMC 1966 351E big block V6 out of a suburban that had 4 speed. Dressed pretty much as it was removed. Ran good when removed, suburban was customized reason for removal. It has PS installed and dealer installed AC parts in box (date coded 12/65). Price $500, needs to go, local pick up. Trying to sell whole to some one who needs, other wise will strip for parts. More photos if needed. AC parts are in a box not installed, under dash type unit by Eaton.
Still editing Last edited by aotte1; 10-25-2023 at 07:43 PM. |
10-25-2023, 08:56 PM | #2 |
Re: Gmc 351e big block v6
Interested in PS including pulleys if you part out
11-04-2023, 10:23 AM | #3 |
Junior Member
So, These are my questions
1) is the Y pipe in tact or cut? 2) is the air cleaner not with it? 3) is the 4 speed still attached and does it come with it or available separately? |
11-27-2023, 05:24 PM | #4 |
The gentleman that owns or runs https://www.olsonsgaskets.com/ (pretty much the only place I can find oil pan gaskets for the GMC v6) needs a donor engine to reverse engineer the rear seal gasket.
I'm guessing this engine is likely the same internally as the 305 (for his purposes) with the exception of the pistons/cylinders? You may see him pop into the classifieds. He saved my bacon because he has gaskets for our trucks. |
11-27-2023, 06:44 PM | #5 | |
11-27-2023, 06:50 PM | #6 |
11-30-2023, 10:53 AM | #7 |
Junior Member
probably gonna have to do a better job of answering questions if Aotte wants to sell anything on here
12-09-2023, 09:36 AM | #8 |
Junior Member
PM sent Aotte - call me
12-09-2023, 10:05 PM | #9 |
I wish I could find one of these near SWMO.
12-10-2023, 11:40 PM | #10 |
No y pipe, only manifold;
Air cleaner came w/engine, not sure origional. No transmission. I have lots going on currently, so may may be slow to respond, thanks for understanding. Last edited by aotte1; 12-14-2023 at 03:29 AM. |
07-24-2024, 12:43 PM | #11 |
Engine going to scraper soon.
07-24-2024, 10:31 PM | #12 |
07-25-2024, 08:48 AM | #13 |
Junior Member
Its so sad to see how the LS swapping and bagging has literally ruined the hobby by pushing out the desire to restore anything to how it came. I blame this modification over restoration mindset for killing interest in parts like your engine. I am broke after just buying the wife a car with all my expendable money but before it gets scrapped, find out what you think they'll pay over the scales and I'll pay that and I will come after it despite having two already and definitely not needing a third. I just can't let it go to scrap. 800 lb engine x Kentucky's 160 per ton scrap rate (engines and cars) gonna be about a $130 payday at the scales is my guess
