Old 11-05-2023, 01:59 PM   #1
cff
Active Member
64 chevy truck 12 bolt
Do some truck 12 bolts have a thin spacer/shim behind the axle bearing? Like it would be spacer/shim, then bearing and seal?
cff is offline   Reply With Quote
Old 11-05-2023, 03:11 PM   #2
Agv63
Re: 64 chevy truck 12 bolt
When i did bearings on my 63 i noticed it. In my mind, its a shield, to keep oil on the bearing if there is a leak and level drops low for no oil to be in tube, i could be wrong but thats what i make of it.
Cheers.
Adriaan.
Agv63 is offline   Reply With Quote
Old 11-05-2023, 07:29 PM   #3
cff
Active Member
Thank you for answering that for me. Cause I was changing my bearings and seals and came across this and it seemed like a factory installed item but just wanted to confirm.
