Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-17-2023, 09:26 PM   #1
Ledslinger
1962 GMC K1000 Suburaban rear cab supports
Does anyone have rear cab supports for 1962 Suburbans? I assume they are the same for GMC and Chevrolet and for 2WD and 4WD.
I'm talking about the support that bridges the inner rocker panel and the body behind and goes from the inner rocker about 10" or so. The front ones are like pickups, but I don't think the rear ones are.
Ledslinger is offline   Reply With Quote
Old 12-03-2023, 07:50 PM   #2
Old Radio Tech
Re: 1962 GMC K1000 Suburaban rear cab supports
I had to make them for my 65. 2 piece welded together down the centerline? took 3 tries to get the shape and angles right. Good luck.
Old Radio Tech is offline   Reply With Quote
Old 12-04-2023, 08:36 AM   #3
Ledslinger
Main problem is no pattern since they are rusted away. I have one not great picture that I'm not sure is an original. To fabricate, I was planning three piece welded on the corners.
Old 12-10-2023, 08:08 PM   #4
Old Radio Tech
Not sure if 62 GMC and 65 Chevy were the same. I started with poster board and cut forms till they fit well then transferred to metal. If your interested I'll dig the poster board stencils out and take pictures and send to you with measurements. If I remember right there were 3 layers to the outside vertical, lower pillar furthest out, then inner rocker, then body support.
Old 12-15-2023, 09:08 PM   #5
Ledslinger
Old Radio Tech - Pictures and measurements would be awesome and greatly appreciated. Thanks
Old 12-24-2023, 03:56 AM   #6
Old Radio Tech
Sorry, I forgot about it. Made not to get to you tomorrow.
Old 12-31-2023, 03:28 PM   #7
pimpston65
pimpston65's Avatar
I have that bridge support from 60-63 if that will work...
pimpston65 is online now   Reply With Quote
