Old 02-15-2024, 11:15 AM   #1
1969stepside
1969stepside's Avatar
69 c-10 vin plate location
so i have a question. the vin plate on my truck was removed by the body shop to fix some rust that was around it. the vin plate has not been changed my question is what is the measurments for the location for the two plates that go in the door jam. i am asking you all this because the owner of the body shop that had my truck has passed away so now i am left answering questions and figuring out what was done. i want to state that this vin is the vin that goes with this truck so there is no shady stuff going on with it. i just need to put it back where it belongs. the truck was made in canada if that makes any diffrence. there is a gvw plate and a vin plate. any help would be welcomed
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-22-2024, 09:05 PM   #2
CKfan
Re: 69 c-10 vin plate location
Hmmm looks like no-one wants a piece of this action (Vin plate issues).
With that said, it is a 99.9% bet the body shop did not weld in the (4) rivet holes where the plates affix (2 top plate, 2 lower of course).
So, just reach behind the B pillar with your hand and feel the push through nubs of the filler they used and there you go. Putty knife it off and use an angled pick to push it through the front.
Good luck.
Last edited by CKfan; 02-22-2024 at 10:57 PM. Reason: Correction I doubled the amount of holes
CKfan is offline   Reply With Quote
Old 02-22-2024, 10:13 PM   #3
georgieb51
georgieb51's Avatar
With that said, it is a 99.9% bet the body shop did not weld in the (8) rivet holes where the plates affix (4 top plate, 4 lower of course).
Good luck.
That is such a good idea! I could have come up with measurements but your idea is the most accurate.
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 02-22-2024, 10:57 PM   #4
zicc1835
zicc1835's Avatar
let us know how you make out ....I have a 69 built in the USA if they are the same ill take measurements an pictures for you if needed
zicc1835 is offline   Reply With Quote
Old 02-22-2024, 10:58 PM   #5
CKfan
Edited my post up top. Should have been 4 holes...2 and 2
Old 02-23-2024, 02:48 PM   #6
697498chevy
Just checked my 1969 C 10 . It's 1" in from outside of door and 1" down from widest point of door bend . HTH
697498chevy is offline   Reply With Quote
Old 03-01-2024, 09:00 PM   #7
zicc1835
zicc1835's Avatar
maybe this helps
