03-22-2024, 07:58 PM | #1 |
Disc brake booster upgrade
Hi all
I am putting a disc brake Dana 44 front under my 70 K20, replacing the original drum brake axle. I'm looking for advice of what brake booster to upgrade to that includes a proportioning valve to support the disc brakes. Is there an aftermarket booster I should be looking at, or get one from a donor truck? Thanks |
03-22-2024, 10:55 PM | #2 |
Born Psycho
Re: Disc brake booster upgrade
if you can find one from a donor truck that would be easiest, when i converted my 69 i had a 72 donor and swapped everything including the steel brake lines to the front end, booster, master, prop valve etc.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-23-2024, 09:33 AM | #3 |
I bought the setup from a member Pickmup trucks . Very nice setup
03-23-2024, 09:39 AM | #4 |
I bought the CPP one for my 72 manual disc/drum conversion to power brakes. Plug and play.
Or look into Tough Stuff dual diaphragm booster for better engine clearance, especially if you have a BB. Get the matching PV for disc/drum from them also or but a combo kit if the offer one. Made in USA My CPP |
03-23-2024, 11:05 AM | #5 | |
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
03-25-2024, 10:08 AM | #6 | |
j
White K20 |
03-25-2024, 10:42 AM | #7 | |
03-27-2024, 12:54 AM | #8 |
All about them K’s
I much prefer hydroboost over vaccum boosters. That’s one of the best changes I’ve made to my 72 K20.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
