03-24-2024, 09:44 PM | #1 |
67 K10 hubs
I need some new hubs for my 67 Chevy K10, one side is not working. Anyway it seems like new hubs are not easy to find for this. I did find one set on eBay that says they fit but they have the bolts around the outside where mine do not. Any advice for me? Will the eBay ones fit? First pic is my hub, second pic are the ones on eBay.
03-25-2024, 04:02 PM | #2 |
Re: 67 K10 hubs
I am 80 percent sure that the Dana Spicer OEM K10 hub will fit. The only unsure part on a 1967 is the splined area of the outer axle shaft. There needs to be a groove on the end for a snap ring retaining the hub clutch. If you can remove that hub that would be helpful.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-25-2024, 05:07 PM | #3 |
Born Psycho
Re: 67 K10 hubs
by the way the set you posted is missing the snap rings and the inner piece the spring rides on.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
03-25-2024, 05:56 PM | #4 |
Re: 67 K10 hubs
This is the hub lock on my '67 K/10 Suburban. It's got aluminum parts.
[Picture edit didn't take. See below.] The Blue plastic knobs are like the ones on my '71 GMC Jimmy K/1500.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-25-2024 at 06:06 PM. |
03-25-2024, 06:05 PM | #5 |
Re: 67 K10 hubs
This is the all aluminum 1967 locking hub.
03-26-2024, 07:45 AM | #6 |
Re: 67 K10 hubs
Here is what the complete setup looks like straight from Dana Spicer
03-26-2024, 05:49 PM | #7 |
Re: 67 K10 hubs
Are they still available NOS from Dana/Spicer, or is it an ebay hunt?
Tags |
4x4, hubs, k10 |
