03-30-2024, 11:47 AM | #1 |
72 C10 weight
Took a load to the dump this morning and got to weigh in and out at the scales. They have a digital readout. Truck is a 72 c10 long box, ps, pb, ac, with a 350. It has front and rear sway bars, 15x8 steel wheels, 31x10.50-15 tires, 10k Curt hitch, and a full tank of gas.
I checked the display after paying, before I got back on the scale. It was 4,040 lbs. give or take 20 lbs. Their scale displays in 20 lbs. increments. I was close, I guessed 4200 |
03-30-2024, 12:12 PM | #2 |
Re: 72 C10 weight
I have a 72 C10 SWB , I was curious what it weighed also, since it isn’t close to original anymore.
Last fall I took the truck up to the local county transfer station, I can weigh for free, unless I want a printed ticket, then they charge a $15 scale fee. Anyway the truck weighs 3540 with a half tank of gas. 3760 with me in it ( I should lose 10 pounds) Truck is radio and heater delete, many other changes as well, Ls swapped with T56 magnum.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
03-30-2024, 12:17 PM | #3 |
Re: 72 C10 weight
Years ago I had a 71 C20 with the stepside bed on it. Small block, th350 trans, dana 60 rear. I scaled out at 4250 with a half tank and me out of the truck
03-30-2024, 12:17 PM | #4 |
Re: 72 C10 weight
Here is the official GM document, which is for the base equipment. Later in this document, the added weights for each option is listed.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-30-2024, 04:54 PM | #5 |
20' Daredevil (Ret)
Re: 72 C10 weight
Had my K20 weighed many years ago before / after unloading topsoil. Can't recall if I was in the truck, or how much fuel in the tanks (it'll hold 50 gallons).
Anyway, it was 11,300# loaded, and 5300# empty. Three tons of dirt, 40+ miles over the mountain. Steered a bit funny and braking was.... well, I made it without hitting anything. I'll never do that again.
03-30-2024, 07:39 PM | #6 |
Re: 72 C10 weight
Wow! 3tons of dirt!! I bet that was a white knuckled experience
03-31-2024, 01:15 AM | #7 | |
Re: 72 C10 weight
03-31-2024, 01:30 AM | #8 | |
Re: 72 C10 weight
1970 C10 Custom longbed 350/350 |
03-31-2024, 12:53 PM | #9 |
20' Daredevil (Ret)
Re: 72 C10 weight
03-31-2024, 05:40 PM | #10 | |
All about them K’s
Re: 72 C10 weight
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-31-2024, 05:48 PM | #11 |
Post Whore
Re: 72 C10 weight
Linking the threads in case someone is looking for more information.
http://67-72chevytrucks.com/vboard/s...d.php?t=598378
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-31-2024, 09:49 PM | #12 | |
70+ ( Old Skool Club )
Re: 72 C10 weight
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
