Old 04-22-2024, 11:12 AM   #1
Loose Screw
Loose Screw's Avatar
1968 Fan Shroud
Where do I get one?
TIA
Loose Screw is offline   Reply With Quote
Old 04-23-2024, 01:55 PM   #2
tim_mc
tim_mc's Avatar
Re: 1968 Fan Shroud
I got mine from LMC Truck. My SBC is in the I6/4WD rearward position closer to the firewall, so I got a 4WD fan shroud, p/n 32-2826.
https://www.lmctruck.com/mechanical/...and-components
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 04-23-2024, 03:30 PM   #3
Loose Screw
Re: 1968 Fan Shroud
Thanks Amigo! Yeah, Frankintruck has a 350 cobbled into were a I6 used to be, so it is looking like Frankies engine is back closer to the firewall also.
Old 04-27-2024, 10:23 AM   #4
RustyPile
RustyPile's Avatar
Re: 1968 Fan Shroud
Here's another source for old car/truck parts.
https://www.classicindustries.com/?u...6e0f5db346c5e#
RustyPile is offline   Reply With Quote
Old 05-08-2024, 06:48 PM   #5
Loose Screw
Re: 1968 Fan Shroud
Ordered today, Thanks!
Old 05-09-2024, 01:20 PM   #6
mattfranklin
mattfranklin's Avatar
Re: 1968 Fan Shroud
I got one from LMC for my '70 C10. The quality was great. BUT, the warning stickers were on the bottom instead of the top. After trying to fit it and failing, I realized the I had the whole thing upside down because of the stickers. After I carefully peeled and repositioned the stickers it was great. 350, 4spd, all stock locations.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 05-09-2024, 07:12 PM   #7
Loose Screw
Re: 1968 Fan Shroud
There's some guy in China chuckling
Old 05-09-2024, 08:31 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1968 Fan Shroud
Well, they are on the other side of the earth...
~Steven
Simi Valley, CA
Old 05-10-2024, 11:31 AM   #9
Loose Screw
Re: 1968 Fan Shroud
Yep FedX says it will be here tomorrow !
Frankintruck came without a thermostat or a fan shroud. Now as it's starting to warm up here in The Great Desert Southwest, I understand why Frankintruck didn't have a thermostat...it didn't have a fan shroud.....
I hope this shroud will fit in there alright over that cobbled 350 wing ding fan......
The radiator is cobbled in too, it's Huge!
Old 05-10-2024, 11:51 AM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 1968 Fan Shroud
Maybe there's no shroud because of the "cobbled 350 wing ding fan". Guess you'll find out soon!
~Steven
Simi Valley, CA
Old 05-13-2024, 03:57 AM   #11
Loose Screw
Re: 1968 Fan Shroud
Tim's deal worked good with a little bit of finessing.
Didn't have to drill any holes or use any bailing wire.
And yes it's keeping the temp down.....
Thanks!
Old 05-13-2024, 03:54 PM   #12
mattfranklin
Re: 1968 Fan Shroud
Nice.
Thanks!
