Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 05-02-2024, 02:40 PM   #1
Hawkynz
Junior Member
Hawkynz's Avatar
Tejas Steelworks LS Swap Engine Mounts
They are new. I did paint them and install them, but they did not work for my application. I took them back out and never ran them. $75
Tejas SteelWorks Motor Mounts for Squarebody Trucks!
This is your solution for a clean, factory like install on your Squarebody C/K truck! Our 2nd generation mounts eliminate the clamshell bracket, but use the OE rubber clamshell isolators. They are the center of our systematic approach to putting an LS in these trucks. We’ve tried to answer all your questions in our C10 Swap Guide!
Our proprietary engine position allows you to keep the GM truck oil pan flush with the 2wd suspension crossmember, and retain the low mount A/C compressor (Denso 10S17F type is preferred). This position is approximately 3″ forward of “stock’ location, as required to keep the low mount compressor. This saves you $300 or more on an A/C relocation bracket. This is money we strongly suggest you invest in driveshaft upgrades. The factory driveshafts aren’t safe at the potential speeds the LS can turn them to.
These do work in your 4wd Squarebody! They should clear the crossmember under the engine, and allow you to keep the low mount compressor. Transmission and transfer case need to be repositioned. How much will vary depending on combination used.
These mounts are frequently used in 1964-1972 model C10s by swapping in the engine stands from a 1973-1987 model. Most automatic transmissions clear the tunnel without modifications. They will not work in ’72 and earlier 4wd trucks.
Hawkynz is offline   Reply With Quote
Old 05-02-2024, 08:18 PM   #2
Joemomma1
Joemomma1's Avatar
Re: Tejas Steelworks LS Swap Engine Mounts
Am I overlooking the price?
Joemomma1 is offline   Reply With Quote
Old 05-05-2024, 09:19 AM   #3
454C10CHEVY
454C10CHEVY's Avatar
Interested, but did not see price either. I'll be next if Joe momma passes.
72 C10 SWB Stepper 350/TH400 (might sell)
70 C10 SWB Stepper I6/4SPD (CURRENT PROJECT)
00 Silverado Rc 1500 2WD 5.3
09 Silverado Cc 5.3 2WD 4/6 DROP
04 Silverado ext 5.3 4WD
454C10CHEVY is offline   Reply With Quote
Old 05-06-2024, 11:45 AM   #4
Hawkynz
Junior Member
Hawkynz's Avatar
I will sell them for $75
Old 05-06-2024, 09:29 PM   #5
454C10CHEVY
Can I get price shipped to 79706 please
Old 05-13-2024, 02:17 PM   #6
Hawkynz
Junior Member
Hawkynz's Avatar
I will try to get it to you tomorrow. I was in Texas all week for C10 Nationals.
Old 05-14-2024, 05:31 PM   #7
fleetside
fleetside's Avatar
I'm interested.
Shipping to 95901 please if still available.
1968 Chevy Short Step
LQ9/4L80E
#IRSC10
fleetside is offline   Reply With Quote
Old 05-16-2024, 03:32 PM   #8
Hawkynz
Junior Member
Hawkynz's Avatar
Shipping is between $10 small box and $18 medium box for Priority Flat Rate USPS. I believe I can get in in the small box.
Old 05-16-2024, 05:11 PM   #9
454C10CHEVY
Sweet I'll take them. Pm sent
c10, ls swap, squarebody
