Old 01-27-2004, 01:46 AM   #1
cheyenne10
cheyenne10's Avatar
dana 44 parts interchangeable?
Can we use ring and pinions or carriers out of ford dana 44's in our housings?
(i.e. 3.50 gears)
Bob
cheyenne10 is offline   Reply With Quote
Old 01-27-2004, 08:01 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I don't think so the dana 44's in fords are high pinion axles. Assuming you mean the front axle as most fords had the 8 or 9" rear end.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-27-2004, 03:06 PM   #3
cheyenne10
cheyenne10's Avatar
yes talking front ends
Jeeps, dodges, fords, chevys, etc used dana 44 fronts during same time period.
I assume there are different widths but are many parts interchangeable?
Bob
Old 01-29-2004, 11:59 AM   #4
kwmech
All 44 parts are interchangable except ford front gears as they are reverse cut, and the early jeeps that were coarse spline spiders. I think there are 3.54 standard cut gears available-- wagoneer if I remember right
Old 01-31-2004, 11:47 PM   #5
leadfoot067
horsepower junkie
ya many waggoneers have the 3.54s...and a standard pinion..
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
