02-01-2004, 05:13 PM | #1 |
64 Chevy Trailing Arm seperation?
Has anyone ever had problems with the trailing arms on chevy pickup with the rear coil spring suspension? I'm in the process of restoring the truck, and noticed much rust / corrosion between the two pieces of metal that are spot welded together, which make up one trailing arm. I'm afraid that some of the spot welds may be ate through. The arms themselves seem solid. I was thinking of drilling a couple of holes and putting in some bolts to make sure the arms stay together. Has anyone done something similar or have any suggestions? Thanks, Tom
P.S. - Have new rear springs and trailing arm bushings ordered, so will be removing the trailing arms. |
02-01-2004, 10:51 PM | #2 |
It is a common problem. you my be able to repair them and weld the seam up. I have some good ones and other parts.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
03-01-2004, 10:32 PM | #3 | |
Re: 64 Chevy Trailing Arm seperation?
03-01-2004, 10:52 PM | #4 |
I just finished fixing up and putting my trailing arms back together on my 64. I drilled out all the spot welds, seperated the arms, cleaned all the rust off with an angel grinder with wire brush, Por15 'ed them, and bolted them back together. I then went around all the seams with paintable latex caulking, and then painted over the caulking. This should keep out all the dirt and mud, and prevent future corrosion. Put new bushings in the arms while I had them apart. Keep em rolling......!
