Old 02-10-2004, 04:25 PM   #1
zyggy72
Can't kick the addiction!
BBC Header question
Has anyone fabricated their own headers for their BBC or had a shop custom fabricate a pair to fit correctly?
zyggy72 is offline   Reply With Quote
Old 02-10-2004, 04:52 PM   #2
Hooter
My other Love
Hooter's Avatar
what made think of going this route? I have a set of hooker headers on my 454 on my 69 and they barely hang half an inch from the bottom of the frame, and I can take my starter in and out with no problems
MEMBER DISCS UP FRONT CLUB
  • 69 custom camper/cst 10
  • 70 monte carlo 383 stroker with a 700r4
  • 77 fully loaded silverado (back in the backyard for a little while longer)
  • 1980 BMW 320i (back in the garage finally)
  • 1981 f@*d f150 4x4 (Robert red ford) tried to kill me
  • 1972 Honda ct 90 trailbike
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com AC/DC RULES!!!
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-10-2004, 05:11 PM   #3
zyggy72
From what I've heard and seen, it is hit or miss with the BBC headers fitting and not having clearance problems with either the frame, starter or tranny/transfercase crossmember. I'm just trying to figure which route I will have to take.
Old 02-10-2004, 05:40 PM   #4
BigDaddyCMU
Are those Hooker headers for a truck or are they 3/4 length headers? The ones that were on my 454 when I got it hung down a good 2-3 inches. When I lower it, it will cause problems.
BigDaddyCMU is offline   Reply With Quote
Old 02-10-2004, 05:58 PM   #5
stepside454
stepside454's Avatar
Bid Daddy, thats why I bought Sanderson shortys for my 454 truck, the Cyclones that were on it & Hookers both hung way to low. John
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 02-10-2004, 07:34 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've used Hookers forever with great results (sounds dirty). Then, I got these for my big block 70 model. I returned them due to oil pan and starter clearance. The starter was less than 1/4 inch from the tube.
I bought GM manifolds and am very happy now.
Hooker header abortion on BBC........
Old 02-10-2004, 08:09 PM   #7
Bluegoose972
I tried to find a set of headers for my big block that I just installed in my 4x4 Blazer, with no luck. I talked with all the major manufacturers and they all gave me the same story...The 4x4's were not designed for big blocks and using the small block mounting location prevents header installation. Some guys have been able to make it work, but I was not able to. I ended up just reusing my cast iron manifolds for not. Sanderson does offer a performance cast iron manifold that looks like they may fit our tight applications.
I currently see three options.
1) Fabricating a new crossmember to give clearance which would also require some trimming of the frame (I shifted the engine forward 2" to help clear the firewall and the frame necks in, making the front header tubes very tight.
2) Having a shop fabricate a custom set of headers. I've already been told that they start at $1000 and go up from there since they are very time consuming.
3) Stick with cast iron manifolds.
For right now and since money doesn't grow on trees, option #3 is my choice!
Hope this helps,
Rick
Bluegoose972 is offline   Reply With Quote
Old 02-10-2004, 08:57 PM   #8
72SWB4X4
Florida Key's Member
72SWB4X4's Avatar
headers
i have hedman BB headers on my truck and they work awesome i ordered 72 bb 2wheel drive and they work on the 4x4
Craig Wood
1972 SWB Chevy Cheyenne 4X4
Restored stock except 454 (481 cu. in. now)
most options Available
pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528
Come to florida and visit www.Paradisewatersports.com
72SWB4X4 is offline   Reply With Quote
Old 02-10-2004, 11:21 PM   #9
Bluegoose972
72SWB,
How was your BB installed? Small block location? Shifted forward? I'm really curious on why I can't seem to fit headers yet I've heard others, including yourself who have not had problems. I ordered a set from Hedman and they ran right into the small block crossmember on the drivers side and into the frame and crossmember on the passenger side.
Any help would be appreciated.
Rick
Old 02-10-2004, 11:53 PM   #10
72SWB4X4
72SWB4X4's Avatar
installation
my BB was installed in the stock SB location in front of the stock 350 turbo
it is on the SB frame mounts ... it all works good i had to grind down the bolts coming out of the firewall that hit the valve covers and pass side had to gring frame slightly about 1/8 to 1/4 inch for header
Craig Wood
Old 10-04-2007, 10:14 PM   #11
DieselEater
DieselEater's Avatar
Re: BBC Header question
So is there anything new out there for 4X4 67-72's WITH MANUAL TRANNY LINKAGE??
A.......
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 10-04-2007, 10:49 PM   #12
snj8198
snj8198's Avatar
i bolted my mkIV block in the stock location with the small block crossmember and mounts and am useing a set of 1 3/4" primary 3" collector full length hooker comps. i ended up with plenty of room around the manual trans linkage, oil filter, gear reduction starter, and surprisingly im left with enough room to get 3" dual exhaust past a np205 and crossmember without a bunch of crazy bends. but i can't find my recept with the part number. figures?! -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 10-04-2007, 11:02 PM   #13
DieselEater
How bout a pic....
A.....
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
