Old 02-11-2004, 12:44 PM   #1
aggiedave98
89 1/2 ton 2wd lift kit, rims, tires
I've got an '89 suburban 1/2 ton 2wd. I'm looking to do a suspension lift, rims and tires. Maybe a 3" lift and 32x12.5r15 tires.
Does anybody know if the front suspension of a 87 chevy truck is the same as the 89 suburban? The reason I ask is because I'm having a tough time finding a suspension lift for an '89 suburban 2wd.
What are recommendations?
Thanks for any help!!
aggiedave98 is offline   Reply With Quote
Old 02-11-2004, 05:22 PM   #2
alf4444
alf4444's Avatar
Should be are you looking at the fabtech lift, looks like they list it for trucks subs and blazers 73-87 but I don't think the subs or blazers changed their front suspension at all from 73-91
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 02-16-2004, 12:50 AM   #3
Dropped90Burb
Dropped90Burb's Avatar
The 73-87 pickup suspension is the same as the 89-91 suburban/blazer. I had the same problem when I was looking to lower my 90 sub. I was told my chassis was the same as the 73-87. I had no problem bolting the parts right up! Good luck and post some pics when you get it done!
Dropped90Burb is offline   Reply With Quote
Old 02-16-2004, 12:29 PM   #4
Grim Reaper
Post some pics when you do it. I have concidered the same. I was going to do bags for the rear so I could adjust for cargo.
Most of the 2wd pre runner folks will tell you with the stock suspension mounting locations 3 inches is about it while retaining a near stock ride.
Other option but I don't care for this is a body lift.
Now here is some info. A 32 will fit with little or no trimming on a 3/4 ton burb with the right offset wheel. 1/2 ton sites about 2 inches lower then 3/4. My 88 3/4 came stock with 235 85 16's and if you do the match thats about 31.5 inches. It's a skinny tire on a skinny 6.5 inch wide rim. a 32 11.5 on a 8 inch rim with 4 inches of back space may just fit or with some minor trimming of the lowest point on the wheel opening and be able to fit with no lift.
Michael at http://www.mkparker.com/goose/ had 35's on his 2wd with bulged fiberglass fenders and no lift.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
