Old 02-23-2004, 10:07 PM   #1
matiii1
rear sway bar
Can you add a rear sway bar to an 85 c20 suburban.It has leave springs and the only kit I can find is for coil spring rears.Thanks...
matiii1 is offline   Reply With Quote
Old 02-24-2004, 11:02 AM   #2
KShortell
KShortell's Avatar
You can, but some vendors require a little bit of fab work to make it fit. I thought about it years ago, but decided not to go that route. There's a lot of debate out there as to whether it'll increase rear wheel skip or not. But, then, lots of '90s and current Suburbans had 'em from the factory.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 02-25-2004, 11:25 PM   #3
perry
try to order one from hellwig i just got mine in the mail for my 89 burb with a dana 60 rear
perry is offline   Reply With Quote
Old 02-27-2004, 11:35 AM   #4
Grim Reaper
60 rear in a 89? did you swap that in? Should have a 14 if it's a 3/4 or has one of the HD towing packages. If it had the 454 it got the Big full floater 14.
Take some pictures of that bar install .I'm intersted in doing the same on my 88.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 03-04-2004, 02:50 PM   #5
perry
i switched rears from a 1982 30 series pickup,i havnt had a chance to put the rear sway bar in yet, but it looks like a easy job
Old 03-17-2004, 11:28 PM   #6
Lee R.
Try Performance Suspension Technology at www.p-s-t.com They have a listing for a 1" diameter rear sway bar kit for all 73-91 Suburbans for $119 or for $159 with poly bushings.
Lee R. is offline   Reply With Quote
Old 03-18-2004, 07:46 PM   #7
ALASKA ALUMINUM BEAR
ALASKA ALUMINUM BEAR's Avatar
TRY THIS INSTEAD
HELLO KIND SIR
TRY THIS ON-----AND IF YOU LIKE BEING DIFFERANT---THIS IS IT---AND NO FAB WORK AT ALL IN THE LEAST
Procomp---makes a set of traction ladders for that year--instead of sway bars--
these are truley an unbelivable additions to youR rig......they stop everything and allow your rig to go down the road stright as a arrow.....come with all bolt on hard wear...
then they have a futher kit-- that can bolt on 4 shocks to both sides of the ladder bars----and it creates a race car effect when driving---and stops all sideway body roll as well.....
if you want something to do to your rig a long the lines you mention----then this is an amazing way to go and looks cooler then anything out there.....
i run them both front and rear with 8 shocks and i can out manuver a vette on a race corce---true story---they are that good......not to spendy either,,,,,about 280.00 for the rear pair....go to procomps web and look at ther page on them.....
hope this plants an idea to be differant...
best of luck
THE ALASKAN ALUMINUM BEAR
ALASKA ALUMINUM BEAR is offline   Reply With Quote
Old 03-26-2004, 01:54 AM   #8
sierrasports
BANNED
we offer a bolt on suspension / sway helper for about $60 plus shipping. just email me - i take paypal to
ill send you some pics
I-Am-Banned
sierrasports is offline   Reply With Quote
