Old 03-16-2004, 12:05 AM   #1
orangeuavol
GO VOLS!
orangeuavol's Avatar
new process 205 transfer case
Does anyone know if a '76 K10 used the NP 205?
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 03-16-2004, 01:22 AM   #2
chevy blazer guy
Its posible they used one but most likely only if it had a stick in it or was ordered that way.
chevy blazer guy is offline   Reply With Quote
Old 03-16-2004, 01:37 AM   #3
buckshot
buckshot's Avatar
like chevy blazer guy said-if it has the "granny gear" 4-speed it's probably a 205.if it's an auto it's more than likely a 203.
crawl under it and see if it has a small cover with 3 bolt holes on the back.if it does it's a 205.you could go to advance adapters web site they have a picture of how to i.d a 205.
buckshot is offline   Reply With Quote
Old 03-16-2004, 01:29 PM   #4
orangeuavol
GO VOLS!
Thanks! I think I've run across a TH350/NP205 Combo just down the street from me. Now, as for the cross member....my blazer has the original Dana 20 Transfer case, will I have to raise or lower the mounts for the NP205?
Old 03-16-2004, 03:36 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Your '72 has a dana 20? I thought they stopped using the Dana 20 in the K5's in '70. Anyway, a PO swapped the dana 20 in my blazer for a 203 (TH350/NP203). The cross member has blocks between it and the frame to drop the t-case about 2".
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
