Old 03-22-2004, 02:12 AM   #1
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Question Van tilt in a pickup?? Conversion questions
How hard is it to convert a van tilt to fit into a pickup? Im thinking about buying one and i dont know how hard it would be to rig it to fit. any help would be appreciated.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-22-2004, 02:37 AM   #2
Bluegoose972
I just finished the installation of mine today. I still have work todo on the linkage, but the column itself is installed. The installation is very easy. Follow the attached threads that other members have put together and you won't have any problems. The most difficults thing I ran into was cutting the inner tube, since I don't own a dremel. But with a will, there is always a way.
Good luck.
Rick
http://67-72chevytrucks.com/vboard/...t=dremel+column
http://67-72chevytrucks.com/vboard/...lt&pagenumber=2
http://67-72chevytrucks.com/vboard/...ght=tilt+column
Bluegoose972 is offline   Reply With Quote
Old 03-24-2004, 04:59 PM   #3
bigskiohio
Easy swap just get one with key in dash, key in column wont fit to fat
bigskiohio is offline   Reply With Quote
Old 03-24-2004, 05:41 PM   #4
HuggerCST
HuggerCST's Avatar
I'm in the process of installing one now. The only problem I see is that the location of the reverse light switch is higher on the column, and may cause me problems. I hear that some van tilts have this in the right location. Also, getting the rubber pieces (firewall seal, dash piece) on the van tilt is going to be tricky without taking it apart.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-24-2004, 11:07 PM   #5
Rod
You'll have to bend over the lower arm to get the metal floor bracket and rubber boot onto the van tilt. Then bend it back straight.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
