Old 03-25-2004, 09:19 PM   #1
grebus1
grebus1's Avatar
For anyone parting out a Sub
I need the metal backing pieces behind the taillamp and backup lamp assemblies. This requires the cutting in this section of the body panel. Can you help?
Does anyone know if these parts are interchangeable between the pickup/blazer/suburban?
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 03-25-2004, 09:32 PM   #2
bagged91
Out draggin'
bagged91's Avatar
I have a 72 burb that I am beginning to part. Do you have access to a digital camera so that you can take a pic of the areas you need? I'm not 100% positive mine are good either but it's worth a shot. The gas filler area is already spoken for as are the inside wheel tubs and all of the doors & glass.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 03-26-2004, 02:55 AM   #3
grebus1
grebus1's Avatar
Here is a pic with an approximation of what I need. I bought this same patch panel but it does not include the taillamp/backup lamp backing pieces. The red outline is probably the minimum amount that would need to be cut out of a donor panel.
Old 03-26-2004, 02:44 PM   #4
ckhd
ckhd's Avatar
Are you sure those don't come out? They do in the pickups...
I don't have a 'burb to cut for you, but now I have to go look at mine to see how it is...
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-26-2004, 04:38 PM   #5
grebus1
grebus1's Avatar
I'm actually not sure if they come out or not. The truck is at a body shop right now and this is the only thing that is holding it up! The body guy seemed to think (by looking at the other side) that the backing pieces are at least tack welded in place. Does anyone know for sure?
Old 03-26-2004, 11:47 PM   #6
bagged91
Out draggin'
bagged91's Avatar
Are you talking about the silver looking pieces that the bulbs go into(refelectors)? If so, I know I at least have the pass side and both backup lights. The drivers side is in there but it may be rotted at the top as it is loose in the body...
I will check on them tommorrow for you...
L8R - Joe
92 GMC K1500 Burb
Old 03-27-2004, 12:34 AM   #7
ghetocrewzer
ghetocrewzer's Avatar
should be able to cut those spot welds out of your old fillers and use them in the new patches. They do spot weld in. I wish I hadn't just thrown mine away. I put Avalanche tails in mine and threw the whole corners out for scrap. Sorry
ghetocrewzer is offline   Reply With Quote
Old 03-27-2004, 03:50 PM   #8
grebus1
grebus1's Avatar
Yeah, the problem is that the body shop didn't realize they needed the backing pieces until they had already junked the old ones. That's why I'm looking...
Bagged, what I need isn't the lamp assembly itself, but the backing section behind the taillamp assembly and backup assembly. Some might call it a pocket--it is a separate piece that is spot welded in.
Old 03-28-2004, 11:17 AM   #9
bagged91
Out draggin'
bagged91's Avatar
I HAVE THEM!!!
I have them for you. Sent you a PM...
92 GMC K1500 Burb
Old 03-28-2004, 10:21 PM   #10
sub4rvr
sub4rvr's Avatar
Hey bagged91, are the door locks any good on the sub you are going to part out? I could use 3 good locks that are keyed alike.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
Old 03-29-2004, 12:16 AM   #11
bagged91
Out draggin'
bagged91's Avatar
sub4rvr-
Me too!! Out of BOTH subs that I have, I don't have one door that locks!!! None of the keys work in them...
92 GMC K1500 Burb
Old 04-02-2004, 12:52 AM   #12
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
It looks like bagged91 has what you need. If not, then let me know...or if anyone else needs them here are pics.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
