Old 04-13-2004, 12:33 AM   #1
2birds40
2wd to 4wd
hi guys and gals great site i have a 86 2wd pickup that i want to convert to 4wd other than axle and transfer case what else do i need to complete this and can my current 700r4 be used or will i need a different one
2birds40 is offline   Reply With Quote
Old 04-13-2004, 01:04 AM   #2
Prerunner1982
Prerunner1982's Avatar
stroll on over to the suspension forum, and search back a few pages, there have been a few 2wd to 4wd threads.. good luck. BUT if you cant find it check back here and we will help ya out.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-13-2004, 01:40 AM   #3
2birds40
ok i looked back 14 pages and didnt find anything can some one help me out on where to look for info or let me now what i got to get and do to get this project rolling thanks in advance
Old 04-13-2004, 02:08 AM   #4
1972C10
1972C10's Avatar
You will have to have the front crossmember for the 4WD , You would also need to get either another trans or have a differnet output shaft put on yours 4WD's Use a short output shaft the transmission crossmemebr is different "I belive"
Steering GearBox Is different , All the leaf spring stuff for the front you would need that.
1972C10 is offline   Reply With Quote
Old 04-13-2004, 02:14 AM   #5
Russell
Professional Grade
Russell's Avatar
The easiest way to do it would be to get a 4x4 truck version of your truck with a nasty body and a blown engine, then drop your body and engine on instead...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-13-2004, 02:28 AM   #6
2birds40
yeah i thougt about getting a different frame but can't seem to find any i also have a 14bolt and 60 sitting here so i decided to just go this route so after rounding up all the parts do they just bolt in or what i would like to get started real soon so as much info as i can get would be great
Old 04-13-2004, 03:22 AM   #7
Russell
Professional Grade
Russell's Avatar
Ok, I don't know much about this (never seen it done, or done it myself) and I'm not saying that I'm right about what I am about to say, but here goes:
From what I have hear, you need to have ALL of the front suspension components, axle, steering setup, leaf springs & brackets etc, you also need the 4x4 crossmember. You then need to remove everything from, and including, the transmission crossmember up. You need to do some measuring and alignment stuff to be sure that you will be bolting the 4x4 stuff up properly. After you're done this, you gotta drill some holes in your frame so you can bolt the 4x4 crossmember, and transmission crossmember up.
You then need the custom driveshafts (unless you did a very good measuring job) and I'm sure a ton of other little things none of us will know about unless we are doing the job. Also may have some clearance issues with stuff like headers and such.
By far it would be much easier to find yourself a 4x4 frame, and just take those components that you already have and put them in if they are better than the components on the new frame, and sell the rest to help pay the frame off.
I'm sure that there are at least a couple of these old trucks in a 4x4 version around there somewhere Check all the wrecking yards and classifieds. I'm sure you'd be saving yourself a lot of headache going that path rather than trying to do a conversion.
Old 04-13-2004, 03:25 AM   #8
1FaastC10
1FaastC10's Avatar
Dana 60s are overrated, i'll trade you a pair of 10 bolts for it. i'm in the process of doing the same with my C10. not only did i want to go from 2wd to 4wd, but from LWB to SWB too. i just bought a parts truck.
1FaastC10 is offline   Reply With Quote
Old 04-13-2004, 08:46 AM   #9
2birds40
thanks guys so in a nut shell i just take everything from a 4x4 and bolt it to my frame after alling and drilling all the holes 1fastc10 i will have to pass but was tempted is there any unexpected things you have run into and why is there problems with headers arent the frames the same in size
Old 04-13-2004, 10:22 AM   #10
Russell
Professional Grade
Russell's Avatar
It has something to do with the 4x4 crossmember that messes things up...
Old 04-13-2004, 03:32 PM   #11
Prerunner1982
http://67-72chevytrucks.com/vboard/s...threadid=97788
there is the other thread, it was in 4x4 not suspension.. DOH!
Jon
Oklahoma Roll Call
Old 04-13-2004, 04:07 PM   #12
2birds40
ok but they are talking about the 67-72 trucks are the frames the same as ours are if so i have a 67 4wd frame sitting here i could use but i was under the impression the it was a completly different breed of dog
Old 04-13-2004, 04:21 PM   #13
Prerunner1982
it maybe, but the idea is still the same.
Jon
Oklahoma Roll Call
Old 04-13-2004, 05:52 PM   #14
1FaastC10
1FaastC10's Avatar
AFAIK, the headers will not work. i think the 4x4 headers mount differently, putting the collectors further inboard to clear the shackle bolts. i think trans/case crossmembers are slightly different too, so you may have problems with clearance and where the collectors exit.
Old 04-13-2004, 06:15 PM   #15
2birds40
so i can install 4x4 headers just not 2wd headers
