Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-16-2013, 08:57 PM   #1
Robertjust777
Need help with choosing a cam, 402 bbc
Need help picking a cam for my bbc first one ive done I want to go as much lift as I can but without clearance issues obviously
cam and lifter set hyd/ or solid cant afford to go roller
1970 396/402 bored 60 over
which I believe is a 414?
im going to be running 411 gears 3200 stall th400 trans
oval port heads cast 3964290
headers 3inch intake is probably air gap
crane roller rockers 1/7 there is power brakes front disc,
pretty much looking to have a real nasty sound
with decent perf, if its a radical idle with not the best street manners no big deal.
Robertjust777 is offline   Reply With Quote
Old 12-16-2013, 09:17 PM   #2
Blue Rat
Re: Need help with choosing a cam, 402 bbc
CR around 10.1 or little higher. I think this would do good.
http://www.summitracing.com/parts/cc...make/chevrolet
Blue Rat is offline   Reply With Quote
Old 12-16-2013, 09:23 PM   #3
Robertjust777
10,5 maybe 11.5.
Old 12-16-2013, 10:04 PM   #4
Robertjust777
i was thinking maybe something like this
http://www.compcams.com/Technical/Dy...94H-10_001.asp
or
http://www.summitracing.com/parts/CCA-CL12-602-4/
Old 12-17-2013, 03:31 AM   #5
Blue Rat
Originally Posted by Robertjust777 View Post
Those are small block camshafts. They will not interchange with each other. Either that or you had a typo?
Old 12-17-2013, 12:07 PM   #6
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Well if you want a cam that sounds like it can take on the world look no further than the comp cams thumper series. Power wise not great , however you stated that was ok.. They sounds nasty as hell. I call them a good show boat cam I installed a 299 thumper for a buddy that has a 396 that is 9.5 comp ratio and its sounds wicked. Has decent manners and runs very well not a power house but he loves it. HYD roller is a nice upgrade I do not know if they make it in a flat tappet. But in the end no reason not to go to a hyd roller only makes sense really.
GMR-PERFORMANCE is offline   Reply With Quote
