11-24-2004, 05:25 PM | #26 |
the pic 72 custom camper posted looks like my tank that they cut the gaping hole in the bedside for. im guessing it was a dealer option because its not listen on the option seat
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-24-2004, 07:50 PM | #27 |
Here are some pics from my truck. It sounds like you are considering something different, but I figured it would not be a bad idea to make the thread as comprehensive as possible, especially for future searches.
Hook'em |
11-25-2004, 12:28 AM | #28 |
Still drivin' a Rat Rod
My brothers 72 has the filler necks in the well like that,the only thing is the amount of crap that accumulates on the cap.Of course he's not one to take the highway when a different option presents itself
He's always scraping the junk off with a screwdriver before he opens the cap. Like I said,if you're not into yard farming all the time it won't matter prolly
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-25-2004, 01:33 AM | #29 |
Lovin' Life in Miss.!
K, I finally got pics. As you can see, this would be a super easy install if you can find the parts. I see these from time to time in the local yards. Will start grabbin some I think. Could be used for the blazer tank conversion I think.
The truck... you hear that? No really, you did hear that?!!! |
11-26-2004, 12:19 AM | #30 |
Dealer installed used the silver doors or filled through the wheel well. Factory installed came up through the box with the blazer shroud around the hose and filler neck. Factory units were only installed on the driver's side.
Bob
V-6....only GMC Trucks have it! 62 GMC W5000 NAPCO-V6 65 GMC 2500 NAPCO Panel-V6 66 GMC 1000-V6 66 GMC 1500-V6 67 GMC K1500-SBC (originally a KM-V6) 68 GMC C1500-V6 68 GMC C1500-V6 68 GMC Suburban C2500 70 Chevy K20-SBC 71 Chevy C30 Longhorn-SBC 72 GMC Suburban C1500-BBC 72 Chevy C10-SBC 72 GMC C5500-ToroFlow Diesel |
11-27-2004, 02:09 AM | #31 |
My nephew gave me an idea..... put the filler neck inside the rear side marker hole. So with a little designing and some modification I put my filler cap behind the left rear side marker. I made a hinged plate and mounted the whole marker on so it would hinge forward to access the filler cap. It took a little trial and error but I finally got it to where it would work.
11-27-2004, 02:13 AM | #32 | |
11-28-2004, 09:50 AM | #33 |
Hook'em, you're not going to believe this, but I have a low-tech solution for keeping the aux tank filler neck & cap reasonably clean during road travel. You know the can coolers that come in half-inch foam? Duct tape the bottom hole shut from both sides, and then simply slip it over the cap. As long as you have a stretched friction fit, it stays put. Pull it off to refill the tank and you'll find little to no dirt. The dirt won't even work its way up much from the bottom. If loose to start, just add a lining to size it.
For bling bling set-up, tie-wrap a cut and slit can cooler to the neck just below the filler cap. Then you'll have a slip-fit seal from the bottom. Just make sure you still have the friction fit with the cap.:p In dutiful exchange for this tidbit, please tell me who made those tanks and if they're still available. I also missed whether those wheelwell-exiting filler necks were original or mods. Since those tanks don't fill thru the body, will they work with a 67-72 Suburban? And does anyone know whether the saddle tanks using bodyside fillers can work with a Sub given minor fuel spout routing mods? Would the spout fit behind the Sub's driver's side pass window assy when rolled down? Looks like the factory installed blazer style necks would interfere with the window coming down, but maybe the lower mounted fuel door spouts would work.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 05:06 PM. |
11-28-2004, 11:24 AM | #34 |
4X4Poet,
I've seen a couple of suburbans with what looks to be a factory installed auxiliary fuel tank on the driver's side that filled through a filler neck similar to the one for the main gas tank. I didn't get to see if it was listed on the glove box option sheet though. Another member from California reported seeing dual auxiliary tanks with the same setup in a salvage yard. Not sure where the filler neck came out on the passenger side on that one, it was gone before he could get pictures. Bob
11-28-2004, 04:02 PM | #35 |
Thanks Bob. I appreciate all the input and pics. I'm planning a Christmas road trip to Sacramento in my K10, and I only have a 21 gal MTS poly tank, so I'm very interested in this thread.
I question the sighting of a pass side Burb tank with bodyside filler since that would be a tight fit with the third door there. Not impossible, just not probable. Like you said, you only had it on account. In any case, I hope to source, or have built, some wheelwell filler saddle tanks like Hook'em posted.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 04:04 PM. |
11-28-2004, 04:15 PM | #36 |
Thanks for the good idea re: filler neck in wheel well. I have no idea where to get saddle tanks like those; they are not on the option sheet but look as though they have been there a long time. Currently, I don't uses either one. One has some rust inside and the cab tank is plenty big for my traveling. I just like the look of them and they make great conversation. Some day I may redo and start using them, so I am going to keep them right where they are.
Hook'em |
11-29-2004, 11:40 PM | #37 |
I bought a set of saddle tanks from a board member today, and was wondering the best was to clean them as they are really dirty and who knows what on the inside, plus info on installing a sending unit in them (if possible, which everything usually is). any help would be great..
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
11-30-2004, 12:41 AM | #38 | |
huh ???
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-30-2004, 01:19 AM | #39 |
Is there a way to install a sending unit if one is not previously installed?
11-30-2004, 02:57 AM | #40 |
There is a way to install a sending unit in most any tank....In the event there is not the required opening that fits the sending units; a trim ring kit is available....Recalls this consists of a gasket; a ring about 3 inches in diameter with threaded holes that fit the sending unit. There are also other holes that bolt the ring to the tank itself.....Will try to locate this source for these adapter rings thru a local source and post.... I recall I used sending units from J.C. Whitney, wired in a 3 position switch to the sending units and the stock fuel guage; thus giving reading for the main and each of the two underbed auxillary tanks.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
11-30-2004, 03:06 AM | #41 |
My other Love
I will take pics of my fuel doors that I put on from a 78 chevy truck, as soon as I get my camera working with my computer agian, I had those ugly aluminum doors as well, and and hated them too
MEMBER DISCS UP FRONT CLUB
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
11-30-2004, 05:09 PM | #42 | |
12-01-2004, 02:12 AM | #43 |
Not a bad nut after all..
I have a saddle tank that needs cleaning, also. It doesn't have a sending unit, so the only opening is the filler neck (can't see much inside). I'm concerned about the gas tank sealer plugging up the gas pickup (justified or not--I can't see it anyway), so I've thought about just treating it with autobody metal prep. Any thoughts on using autobody metal prep only?
12-01-2004, 02:32 AM | #44 |
Go to www.por-15.com they have a product called marine clean that works pretty good. They also have a product called US Standard that is supposed to be a good tank sealer. I doubt you would have a problem with it clogging your pick-up if you follow their instructions. In regards to the sender. I could not find a replacement for mine so I put in a (I think) VDO adjustable sending unit. I had to re-drill the mounting holes but otherwise it was a perfect fit. Came with everthing I needed for the indstall also.
12-01-2004, 08:26 AM | #45 |
I bought a fuel gauge and float from JC Whitney a few years ago for less than $50. I think it was more like $25. After I had a shop boil out and seal my tank I installed the float/sender setup and mounted the gauge knee-knocker style under my dash.
The fuel is picked up out of a tube that comes out of the top of the tank. The bottom of the tube doesn't quite reach the bottom. I attempted to make the JC Whitney float work out of the fuel tube's hole but there wasn't enough room so I just made another hole. The pick-up tube and tank level sensor are in two different holes.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-01-2004, 09:48 AM | #46 |
fuel gauge/float sender
checked J.C. Whitney web site. They have fuel gauge and float sender for $22.95 !! requires a 2 1/8 hole to mount the float.....Jim
12-02-2004, 07:03 PM | #47 |
Franko72
my 72 has the factory install dual saddle tanks.drivers side filler is on the side of the bed panel with the gas cap and rubber grommet.The passenger side filler is located thru the rear fender well between the front of the rear tire and the bed side.The filler tube extends out of the back end of the saddle tank and angles upward . It is hardly visible.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
Thread Tools | |
Display Modes | |
