11-21-2004, 11:40 PM | #1 |
Saddle tanks
I was wondering if anyone has a picture of their truck with saddle tanks and where the filler neck is.
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
11-21-2004, 11:56 PM | #2 |
My truck has saddles on both sides. The filler necks comes out into the rear wheel wells. I will try to post a pic tomorrow, if no one else posts a pic.
Hook'em |
11-22-2004, 12:00 AM | #3 |
i have two saddle tanks the dealer torched the holes into the bedsides and it used to have aluminum doors like were on motorhomes
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. Last edited by cableguy0; 05-12-2006 at 02:37 AM. |
11-22-2004, 12:05 AM | #4 |
huh ???
My 72 use to have a factory installed drivers side saddle tank. The filler neck came through the bed side like a blazer neck a few inches behind the cab neck. I don't have any pics though because my uncle removed the tank due to rust before he gave me the truck...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-22-2004, 12:28 AM | #5 |
Next project: 1970 K10
You can see the doors on my 70, not sure if the dealer or the factory did them:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
11-22-2004, 10:05 AM | #6 |
20' Daredevil (Ret)
My twin saddle tanks (Travel Tanks brand) have aluminum doors in the same location as the above pics. Very short straight filler necks come straight up from the tanks.
11-22-2004, 10:24 AM | #7 |
Lovin' Life in Miss.!
I have the Blazer bedside style. On inside of bed there is a panel that covers up the filler neck assembly. If I had one of those aluminum door access panels I would trash it and put in some kind of modern filler door.
The truck... you hear that? No really, you did hear that?!!! |
11-22-2004, 11:01 AM | #8 |
Is there any way to route the filler neck to the inside of the bed?
11-22-2004, 02:38 PM | #9 |
ok, maybe I'm a radical. Or maybe it's cause I'm Canadian & the snow & cold made me this way. But it just Blows my mind that people go to the trouble of moving their tanks then put the filler inside the bed. no matter how many gazzilion dollars goes into these trucks, when I see a filler in the bottom of the bed I think,,, well,,, there not nice thoughts. But then I intend on using my truck to perhaps haul stuff. Just my opinion, to each his own.
11-22-2004, 02:47 PM | #10 |
Well, Purple. The tank itself is pretty much a bolt in. A filler neck in the bed is 1 big hole cut and a little bit of fitting for the collars around the neck. Pretty easy stuff for a novice. Bedside filler doors take a bit of talent with a welder or cash for a person to run said welder.
11-22-2004, 04:15 PM | #11 | |
Anyways...
11-22-2004, 08:12 PM | #12 | |
20' Daredevil (Ret)
11-23-2004, 07:15 AM | #13 |
when I had a some body work and a paint job done in 1989; I had the tanks removed and the filler neck moved so that it was inside the rear well The side fill doors were removed ( they were in poor shape anyhow!) and the hole filled before final bodywork and painting..... I like the cleaner look .. Also, looks like Hook 'Em has done the same thing.......... Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
11-23-2004, 01:13 PM | #14 |
I am looking for the doors on the Glock 35 truck. Are there any avilable aftermarket??
11-23-2004, 03:41 PM | #15 | |
Now just going to a blazer type set-up I have I could do that by myself once I found all the parts. Just a bedside hole to cut out.
11-23-2004, 04:04 PM | #16 |
Is there any way to turn the tank around so the filler neck can go inside the bed. I've never seen what a saddle tank actually looks like..(shape, size, ect). just pondering my possibility's
11-24-2004, 01:27 AM | #17 |
huh ???
Hey 2low72, here's a pic I have from the board of a saddle tank removed...
Chuck
11-24-2004, 01:56 AM | #18 |
That helps, So I could just cut a hole in the bed where the filler neck is and it should work???
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 Last edited by 2low72; 11-24-2004 at 02:11 AM. |
11-24-2004, 08:47 AM | #19 | |
I currently have the aluminum door pop-riveted over a hole hacked in my bedside like many others with this extra tank. When I finally get around to installing my blazer tank I'm going to get two filler doors from the same year/make doner and weld them into the bed side. If you use the blazer tank filler from the factory you have to run it inside the bed and through the floor. I intend to use a scavenged spare tire carrier to cover the filler tube inside the bed. It would be really nice if the filler tube cover could actually be used as a spare tire carrier as that is how I carry my spare now.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
11-24-2004, 10:05 AM | #20 |
ok i see what you mean. How many gallons do they hold?
11-24-2004, 10:08 AM | #21 | |
11-24-2004, 10:10 AM | #22 |
That would be perfect. i guess i might see about finding a newer door if i decide to do it.
11-24-2004, 10:16 AM | #23 |
Still drivin' a Rat Rod
Looks like with some cutting you could run the filler neck about anywhere you want it.It's just a piece of hose right?I would have it come out near the top of the bed on the inside if possible.The aluminum door looks like crap,and the blazer necks leave a little to be desired IMO.
Or you could use a spring fuel door like this s10 jobber here,provided you can weld
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 11-24-2004 at 10:24 AM. |
11-24-2004, 01:50 PM | #24 | |
11-24-2004, 05:22 PM | #25 |
huh ???
Mine was the way chickenwing described. I don't know how the dealer installed came through, but the factory one mine had came up through the bed...
Chuck
