#26 |
Re: 59 Chevy Build
well today I notched the frame and hung the rack. Just taking it easy waiting on all the parts to get here. I decided to go with the HT 502 motor since I will be doing some towing. Anyway here are the latest pics..........
#27 |
Re: 59 Chevy Build
Well, it doesn't look like I got much done these last couple of day.....but I did. Here are a couple of pics of the brake system and the wheels that I chose for this build,,,,,,,,
#28 |
Re: 59 Chevy Build
Haven't been getting a lot done lately. been waiting on parts. Here is a couple of pics of what came today..........It is an HT-502.........512 ft lbs of torque at 2800 rpm. I figure that will serve the purpose of what this truck is intended for.............
#29 |
Re: 59 Chevy Build
Okay.....I feel like I made some major leaps this weekend getting this thing going.........here are a few pics of the progress made...........
#30 |
Re: 59 Chevy Build
Looking great!!!!!!!!!!! Gotta love a big block.
Bernie |
#31 |
Apache Club
Re: 59 Chevy Build
its looking good and coming along quick.
![]() ![]() My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) ![]() |
#32 |
Re: 59 Chevy Build
Nice work man!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#33 |
Re: 59 Chevy Build
Well I reached another milestone today........I decided to go with a power brake system mounted on the firewall. I did this because I plan on using this as a daily driver. I figured it would be easier for serviceability.........
#34 |
Re: 59 Chevy Build
Prostreeter, where did you get thst set up, brake booster and foot pedal?
#35 |
Re: 59 Chevy Build
#36 | |
Re: 59 Chevy Build
#37 |
Re: 59 Chevy Build
#38 |
Re: 59 Chevy Build
Tks bro......
#39 |
Re: 59 Chevy Build
Well I did get some things done today. It is just difficult to try and get much done after you have been at work all day...............anyway the column is set in place so I can order my intermediate shaft. I had my son going around to junk yards today looking for a 9" rear. Anyone got one they wanna let go of??........we found several but I am looking for one that is 54"-56" backplate to backplate................let me know if you come across one.
#40 |
Re: 59 Chevy Build
Nice work man! Your Mustang II set up looks good and the 502....well, that's going to be one serious truck for towing! Keep up the good work!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 06-21-2007 at 12:07 AM. |
#41 |
Re: 59 Chevy Build
Looking good! great choice for the motor. What tranny did you go with? 4L60? 4L80 to handle all that torque?
Love the feather. Steve |
#42 | |
Re: 59 Chevy Build
As for the feather, it was laying in my front yard when we returned from Arizona with the truck, figured it must have meant something.... ![]() |
#43 |
Re: 59 Chevy Build
hey prostreeter58, nice truck. I'm still waiting for your response on the front motor mounts,please let me know whats going on with these.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride ![]() ![]() 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ![]() 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ![]() |
#44 |
Re: 59 Chevy Build
#45 |
Re: 59 Chevy Build
Well it might not look like I got much done today, however, I cut the motor loose and moved it forward about 3/4", then I found a ford 9" that was out of a coil spring car and had about 200 brackets that had to be cut off and ground down. Anyway I roughed in the rear with the triangulated 4 link and tomorrow I will remove the rear and finish welding the new brackets on. Once I remove the bed I will box the aft frame..............
#46 |
tiggerstoy
Re: 59 Chevy Build
wow....alot gets done when i don't come on here often....nice build, love the work, that's gona haul a$$!......ummmm, paint?
#47 |
Re: 59 Chevy Build
Well it seems that progress has slowed to a crawl..........man waiting on parts really drags on. Anyway since I have had the time I welded all those unwanted factory holes closed on the firewall, put the sound barrier on the cab floor and started to fit the air ride to the rear diff.......
#48 |
Yellow truck club
Re: 59 Chevy Build
Man you're moving right along on the build...
You might want to look into changing the mount for the shock waves. Those rivets might not want to support the truck. Most of the kits have an upgraded cross member. Brian ... ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#49 | |
Re: 59 Chevy Build
I have been looking at that.......thinking about reinforcing the existing mounts or ....changing it out totally.....thanks for the "heads up".... |
#50 |
Re: 59 Chevy Build
Got to love it when Santa comes to visit in the summer
