#26 |
Re: 5.3 or 6.0 in my 1970?
I don't know guys. The trailblazer has the 6.0 and we get around 13-14 mpg. I think it would be a little better in a lighter (less than 6k lb) truck. It scoots the Trailblazer along pretty quick, I couldn't imagine the speed in a swb truck weighing in around 3800lb. I think i would spend the extra money on the 6.0 if you are really after power. If you are wanting mpg I would get the 5.3 just because it would be cheaper initial purchase and the gas would be cheaper also. Just my opinion though.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#27 |
I'll chime in on the gas mileage thing just for reference. My last tank was about 60% highway at about 70-75mph. I got about 13.5 mpg. This is with the 6.0L, 38x15.50 tires, and 5.13 gears in a heavy ass Suburban. I gained about 2 mpg with the 5.13's vs 4.10's that I used to have. I would highly recomend the 6.0 over the 5.3, so much more potential for cheap.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
#28 | |
Eat My Rust
#29 |
Windy Corner of a Dirty Street
For whatever it is worth…. my 5.3L Z71 Hoe averages around 18 MPG but it doesn’t see many miles. It pretty much only hauls my skinny butt and 30 lb suitcase and laptop bag back and forth from the COS airport so it only sees highway miles.
I am often amazed how much power the 5.3L doesn’t have in a Hoe with 3:73 gears. Living at 5,000 ft elevation doesn’t help much. It feels like it needs one more gear in the trans to make the powertrain work in symphony. First gear acceleration is decent, second gear okay but the 2-3 shift the 5.3L and 4L60E falls flat on it’s face. I swear there are toe nail marks in the floor mat just to keep up with traffic. One of the most annoying things with this powertrian combo is when I encounter this particular large hill I often encounter when the cruise is set and the trans downshifts from 4th to 2nd gear and the RPM’s jump wayyy the hell up. The 5.3L sounds like the pistons are swapping holes at that point. The RPM jump always scares me to so find myself tapping the brake pedal to release cruise and relax the engine. I am not impressed with the power that my 5.3L delivers in a SUV anyway living at high altitude. Maybe in a lighter truck it would be adaquate. I actually hate this damn Tahoe and want to off it for a Poncho G8 but my wife really likes it and it is 5 payments from being paid off so I guess we are stuck with it for a while. SUV’s aren’t worth 50 cents in resale right now anyway.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#30 |
liked mentioned, if you want more power go 6.0, but mileage is the same, i went from a 5.3 > 6.0 in my 2001 ext cab with 4.10 and still get 15city/19highway, also with a 3200 converter that flashes at 3900, guys let me tell yo this, these new GENIII motors are awesome but you wont believe how much better you can make them if you have them tuned better with like HP tuners or EFI live, if you have them tuned right you can get a whole lot of power out of these motors and more gas efficient....
just to give yall at idea, my truck with the 5.3 went 13.2@99mph and then i swapped to a 6.0 and went 12.43@106, my trucks raceweight is 4700lbs, so I cant imagine a setup like this on a 1000lb lighter truck? which the 5.3 would perform awesome aswell.. these both motors have aftermarket cam only, both are stock heads....... i am also almost getting ready to put a 5.3 in my 68', i found a 2006 5.3 complete longblock with accessories, and 4l60e for $1000, can let go of a deal like that,,,,
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
#31 | |
Always wrenching!!
exactly!! deals are out there. i got a 2004 5.3/4l60e complete for $800 had 20k on it. runs perfect!!
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
#32 | |
Shawn
#33 | |
Always wrenching!!
#34 |
Well there you go! Do you have any trouble with fuel starvation going around corners when the gas in the tank is low and sloshes away from the fuel pickup?
#35 |
![]() Join Date: Dec 2007
Guys,
How much does a 1970 C10 Short weigh? I am going to go with a 6.0l with a 4l80e trans. I think i am just going to get a tune for it and install a cam in it. My wife has a yukon with the 6.0 and it moves! I am sure my little 70 is way lighter than that beast. There was someone on ebay that had pretty good deals on motor combos, but he does not have any 2WD applications. I will continue to look! I am bound to get a good deal on a 6.0 with todays gas prices. How aggressive of a cam can i install (good street manners) in a 6.0? Any suggestions on cams? You guys ROCK! |
#36 |
I have a 5.3/4l60 e in the garage and I am not too far away, interested?? PM me. What everyone is using as the measuring stick isn't necessarily realistic in that one the older truck is about 2k lbs lighter, you'll strip a bunch of emissions crap off of it, and the motor will be (should be anyways!) tuned to do away with the craptastic OE tune that is used to help GM avoid warrantee work, so low rev limiter, terrible shift point/perf, etc, etc. A 5.3 with a 6.0 cam and a tune plus stripping the crippling tune and a 5.3 ought to kick 300-350hp to the tires, right??
#37 |
Yes I switched the gears after the tires. The motor was just lugging too much with the 4.10's. Now I'm about 2400rpm at 70mph and the motor is hardley working, it's great.
As far as a cam, you can go as big as you want. "Good street manners" is a relative term. My truck now has a .551"/.551" 210/218 114lsa cam and it drives great. Little bit of a lope, but not much. Some people think it's too lopey. I'd actually like to go a little bigger. My last Trans am had a .595/.605, 234/240 114lsa cam and it was perfectley streetable too, in my opinion. It's all a matter of opinion. Your limiting factors are going to be valve springs ( stock are only good to about .500 lift ), and needing a higher stall converter if you go real big on the cam.
#38 | |
Eat My Rust
#39 |
Always wrenching!!
dont usually let it get to low, been to just below a 1/4 and didnt have any probs.......
#40 | |
Junior Member
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
#41 |
Hey boost not to get off topic but I would have thought that gear swap would have cost you mpg, by the way I'm getting about 13-15 overall with 33s 6.0, 4L80 and its hard to keep the foot out of it
72 K20 Suburban 6.0L, 4L80, 4Wheel Disc Brakes, Hydroboost, In a Million Pieces(edit) A little closer to done |
#42 |
Yes and no on the 1 ton running gear. I have a 14 bolt rear and 3/4 ton Dana 44 front. One of these times I'll try being a little more patient and try to keep it under 75mph on the freeway. I'm sure my mileage will increase noticeably.
TyJ- Normally the gears would have hurt mileage but I was on the extreme end of wrong gearing. On the freeway the motor was only turning about 1800rpm. When you factor in the awesome aerodynamics of a lifted Suburban, light weight of 38x15.50 tire, and our high elevation it was a little much for the motor. Unless I got up over 70mph or about 2k rpm, there was just too much load on the motor for the converter to even lock up. So that's just wasted rpm. Now with the rpm's up higher where the motor was designed for, I barely have to crack the throttle open to maintain speed. Any time you can take load off a motor, it will use less fuel. FWIW, when I forst did the motor swap, it was bone stock and I had 1/2 ton axles and 35x12.50 tires and only got about 10mpg average. The added power of the cam swap and especially new gearing helped my mileage considerably.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 08-14-2008 at 11:49 PM. |
#43 |
Wow what a great thread! This was kinda what I was looking for when I started this one in the 99+http://67-72chevytrucks.com/vboard/s...d.php?t=304525 $1700. swaps? Hmm Maybe thats a cheaper route then me getting a new/used truck...nah!!!
"Red-heads not war-heads, Blondes, not bombs, Brunettes, not fighter jets!" Fligh of the Choncords 72 burb 3/4 ton 2wd 06 2500 suburban 8.1L 4x4 84 chev 4x4 diesel 96 Geo Metro with the 4cylbb, lol! Almost 300k just won't die! 89 Honda Civic, runs on the smell of an oily rag! 2008 Aerolite 26qs Travel Trailer (aka "THE BARN") |
#44 |
![]() Join Date: Apr 2008
Where are you guys finding these motors so cheap the lowest I have found is $3500.For the 6.0 and trans
#45 |
bigger is always better!! here's my 6.0 waiting to go in my truck... i paid a little too much for mine, but i'm a compulsive buyer, i saw it and i bought it... but who cares; i got what i want.
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
