Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-25-2008, 08:49 PM   #1
nhtc33d
Solid motor mounts
Hello all,
I have done some searching and can't seem to find any solid motor mounts for my 65. I have the stock type single bolt towers. Does anyone know of a company that makes them? Thanks for any help
nhtc33d is offline   Reply With Quote
Old 08-26-2008, 06:53 PM   #2
67dragtruck
67dragtruck's Avatar
Re: Solid motor mounts
Originally Posted by nhtc33d View Post
Hello all,
You could always do a motor plate instead of solid mounts. Otherwise they wouldn't be hard to make for that type of mount.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 08-26-2008, 07:41 PM   #3
shortbed70
shortbed70's Avatar
Where did the plate come from who made it?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-26-2008, 07:48 PM   #4
67dragtruck
I belive I bought that one from Barnett Performance in Atlanta, but Summit or Jegs carries them. Cost about a $100. They come as a big rectangle, but with the timing cover cutout and cutout for the waterpump. You cut it to the shape you want. They actually make them in several styles. I used a mid plate too between the motor and transmission, but I don't think I'd do that without a cage in the truck. I've had several friends run the motor plates only and never had problems.
Tom
Old 08-26-2008, 09:20 PM   #5
shortbed70
shortbed70's Avatar
Yea I'm wasn't going to run one between the motor trans but I was wondering about the front plate thanks I'll look it up.
Troy
Big Red Dog build
Old 08-31-2008, 06:53 PM   #6
scatesracing
Machinist
scatesracing's Avatar
I took the tourch to my stock ones and melted the rubber off of them. and then drilled and tapped some round stock turned a step to fit in the plate for center...... Then welded it all up........ worked slick I tapped it 1/2-13..
scatesracing is offline   Reply With Quote
Old 08-31-2008, 08:30 PM   #7
nhtc33d
You wouldn't have a picture by chance?? Sounds like a great idea! Thanks
Old 09-01-2008, 11:15 AM   #8
scatesracing
Machinist
Sorry.... I dont have any. I would go out and take a pic but the truck is in storage in inman KS at my father inlaws farm. I moved about a year ago and had to give up my shop........ I have a two car garage here but it is a little small......... I may have to kick the wifes honda out and just bring it home Travis
Old 09-01-2008, 08:53 PM   #9
nhtc33d
I looked at mine tonight and i think i understand how you did yours. I may give it a shot tomorrow! Thanks for the help.
Old 09-02-2008, 01:24 AM   #10
71chevytruckguy
71chevytruckguy's Avatar
a company called prothane is making urethane ones. i got mine from summit for about $80. they're a lot stronger lookin the the factory rubber ones. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 09-02-2008, 09:46 AM   #11
57sailplane
57sailplane's Avatar
i think this is what you may be looking for.. they have others also..
http://www.speedwaymotors.com/p/602,...or-Mounts.html
57sailplane is offline   Reply With Quote
Old 09-13-2008, 08:20 AM   #12
ton*loc
ton*loc's Avatar
speedway motors kits ass
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
