Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-09-2008, 04:53 PM   #751
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
Way to go Jim...been a little slow on the old Blazer/Jimmy board.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 10-09-2008, 05:13 PM   #752
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, thought that myself, just waiting for my crossmember to come back from DIY4X...
Hey, nice fix on your frame and rad. support
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-29-2008, 10:05 AM   #753
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got my crossmember back from Kert, added 4 flanges(sons idea for fix) now I can easily drop the pan without supporting engine. Thanks to DIY4X
OFF TOPIC---20lb Salmon fell to a purple egg sucking leach fly...As AJ would say "who's the dork with the fish, wait that's me"
SAFETY FIRST
AS usual, off topic
Jim
Old 10-29-2008, 12:40 PM   #754
Yukon Jack
Yukon Jack's Avatar
Re: PO has me PO'd
Nice modification - and what a beauty of a salmon - makes me very hungry!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-29-2008, 12:45 PM   #755
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Ditto on the nice cross member and nice salmon...but I just had lunch so I'm not so hungry.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 10-29-2008, 06:34 PM   #756
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
I wonder, had you made the mod first, if it would of fit without having to send it back to DIY...?
Adding the plates by themselves might of given enough room for the oil pan clearance.
(just thinking out load here)
Nice mod non the less.
vtblazer is offline   Reply With Quote
Old 10-29-2008, 07:16 PM   #757
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
In the beginning we didn't know what would fix it, he was going to bend a new cross member, untill Jon came up with the flange idea...
My understanding from Kert was that certain oilpans will clear the crossmember, mine was about 1/2" short of lining up the motor mount bolts. Kert felt with the thickness of the flanges(total between 2 is a 1/2" per side) bolt on motor mount is a 9/16", so half of that is like 4.5/16". I needed a half a hole, to get it to line up. That whole paragraph probably doesn't make much sense, but I can still add a spacer between the flanges if I need more space
I'll find out tomorrow, and will be better able to answer your question
SAFETY FIRST
AS usual, off topic
Jim
Old 10-31-2008, 08:20 AM   #758
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
First off, on a safety note, since the engine is only hanging by the manifold plate, I had a sturdy jackstand under the ringgear in case something went wrong...I would like to mention that since Kert added locking nuts welded to the frame plate it makes it alot easier to mount up the crossmember. You don't have to try and hold the nut with a wrench in between the plate and the frame. Nicely thought out product and he was never to busy to take my phone calls
Basic hand tools required...sweet truck!
Modified crossmember
It's still tight, but with a spacer between the flanges, it should be good to go
This pic. shows how you can now drop the pan w/o removing motor mounts
Off the hook
So, to answer your question Kurt, yes it will fit with the addition of the flanges
SAFETY FIRST
AS usual, off topic
Jim
Old 10-31-2008, 08:39 AM   #759
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: PO has me PO'd
Thats some nice progress and the crossmember looks great!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 10-31-2008, 08:42 AM   #760
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I don't know about progress, I've been working in this one area for a month (I was done this area with the stock crossmember and poly mounts), but thanks
SAFETY FIRST
AS usual, off topic
Jim
Old 10-31-2008, 09:03 AM   #761
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Now on to the next problem...I mean opportunity for improvement. Looks good Jim.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 10-31-2008, 09:07 AM   #762
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
You guys don't give much time to rest for us old guys, do ya! lol
Back on to the sparkplug wires that got sliced during storage, got a new set from Jeg's, but they do'nt make them in yellow anymore...gotta call Accel
Brake lines don;t look rite
SAFETY FIRST
AS usual, off topic
Jim
Old 10-31-2008, 12:47 PM   #763
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Awe come on...you're not old!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 10-31-2008, 02:30 PM   #764
Big J
Big J's Avatar
Re: PO has me PO'd
Considering what I've got done to mine in the past 3 months I'd call what you've got done major progress, lol......
BAZINGA!
My Build
Old 11-04-2008, 05:56 PM   #765
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Finally got the oil pan mounted up, one pc. gasket, and grey silicon on all 8 corners(top and bottom of gasket) as recommended by the members
I think this engine is a canidate for Seafoam, coked up... I'll pull the dizzy and make up a shaft to spin the oil pump since I want to prime the entire oil system before starting up the engine
SAFETY FIRST
AS usual, off topic
Jim
Old 11-04-2008, 07:06 PM   #766
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Thanks for the inspiration there buddy!
What do ya think about running to Tenn. in July of 09 in our trucks?
Old 11-04-2008, 07:28 PM   #767
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Would that be a warm up for the Michigan trip?
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-04-2008, 08:37 PM   #768
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, sounds like a nice run...I'd like to meet up with RustyParts and some other members in Tenn. area. Seems like there are alot of cool guys down there. June is out, sons gettin' married. Maybe we'll get Tim to come down, and yes the Mich. trip is still in the works. Guess I better get my arse in gear
Actually, the foe is on the other shoot...you inspire me! Your work is far superior to mine, I would never go where you have gone. Nice job on the Garage, I see many, many happy hours down there
SAFETY FIRST
AS usual, off topic
Jim
Old 11-04-2008, 08:57 PM   #769
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Yeah, they sound like a great bunch.
I've met a couple, looking forward to meeting more...
Mich. is still a 'must do', this only came to mind when I read they were having a gathering in July next year.
Think it's doable for ya Tim?
Old 11-09-2008, 12:19 PM   #770
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Nice work!! Great idea on the crossmember. Did the frame rails spread any when you took it out? Or did it bolt right back in?
btw...love the fish pic!
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 11-09-2008, 08:08 PM   #771
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I'll be able to answer your question in a couple days, parts are painted and waiting for reassembly....didn't appear to move much when I took it out
SAFETY FIRST
AS usual, off topic
Jim
Old 11-13-2008, 04:01 PM   #772
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK, woke up at 4 AM this morning figgered I'd put some time into the truck...got the final crossmember in and buttoned up. I suggest starting all bolts and then tighten down, as this seems to pull everything together evenly, This mod could be done at home, but I didn't want to fool with DIY4X's product in case something went wrong...
AJ, didn't see any pulling or pushing of the frame members while I
installed it
Here's some pics.
I picked up some utility seats from 6t727t2 and my plans are to recover them like the pic supplied by Ironmike
OK, now I'm back to where I was 2 months ago...lol. Also decided to buy a short block, I'll start searching for the best price, maybe GM remanu
SAFETY FIRST
AS usual, off topic
Jim
Old 11-14-2008, 06:58 PM   #773
Big J
Big J's Avatar
Re: PO has me PO'd
Short block? Whats wrong with the one in there?
BAZINGA!
My Build
Old 11-14-2008, 07:06 PM   #774
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Yeah...what he said?
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 11-14-2008, 07:31 PM   #775
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Crossmember looks great. Great choice on the interior...looks like mine!
- AJ
