10-09-2008, 04:53 PM | #751 |
Can't wait to retire!!
Re: PO has me PO'd
Way to go Jim...been a little slow on the old Blazer/Jimmy board.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
10-09-2008, 05:13 PM | #752 | |
Re: PO has me PO'd
Hey, nice fix on your frame and rad. support
10-29-2008, 10:05 AM | #753 |
Re: PO has me PO'd
Got my crossmember back from Kert, added 4 flanges(sons idea for fix) now I can easily drop the pan without supporting engine. Thanks to DIY4X
OFF TOPIC---20lb Salmon fell to a purple egg sucking leach fly...As AJ would say "who's the dork with the fish, wait that's me"
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-31-2008 at 08:39 AM. |
10-29-2008, 12:40 PM | #754 |
Re: PO has me PO'd
Nice modification - and what a beauty of a salmon - makes me very hungry!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-29-2008, 12:45 PM | #755 |
Re: PO has me PO'd
Ditto on the nice cross member and nice salmon...but I just had lunch so I'm not so hungry.
10-29-2008, 06:34 PM | #756 | |
Re: PO has me PO'd
I wonder, had you made the mod first, if it would of fit without having to send it back to DIY...? Adding the plates by themselves might of given enough room for the oil pan clearance. (just thinking out load here) Nice mod non the less. |
10-29-2008, 07:16 PM | #757 | |
Re: PO has me PO'd
My understanding from Kert was that certain oilpans will clear the crossmember, mine was about 1/2" short of lining up the motor mount bolts. Kert felt with the thickness of the flanges(total between 2 is a 1/2" per side) bolt on motor mount is a 9/16", so half of that is like 4.5/16". I needed a half a hole, to get it to line up. That whole paragraph probably doesn't make much sense, but I can still add a spacer between the flanges if I need more space I'll find out tomorrow, and will be better able to answer your question
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-29-2008 at 07:38 PM. |
10-31-2008, 08:20 AM | #758 |
Re: PO has me PO'd
First off, on a safety note, since the engine is only hanging by the manifold plate, I had a sturdy jackstand under the ringgear in case something went wrong...I would like to mention that since Kert added locking nuts welded to the frame plate it makes it alot easier to mount up the crossmember. You don't have to try and hold the nut with a wrench in between the plate and the frame. Nicely thought out product and he was never to busy to take my phone calls
Basic hand tools required...sweet truck! Modified crossmember It's still tight, but with a spacer between the flanges, it should be good to go This pic. shows how you can now drop the pan w/o removing motor mounts Off the hook So, to answer your question Kurt, yes it will fit with the addition of the flanges
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-31-2008 at 08:50 AM. |
10-31-2008, 08:42 AM | #760 |
Re: PO has me PO'd
I don't know about progress, I've been working in this one area for a month (I was done this area with the stock crossmember and poly mounts), but thanks
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-31-2008 at 08:45 AM. |
10-31-2008, 09:03 AM | #761 |
Re: PO has me PO'd
Now on to the next problem...I mean opportunity for improvement. Looks good Jim.
10-31-2008, 09:07 AM | #762 | |
Re: PO has me PO'd
Back on to the sparkplug wires that got sliced during storage, got a new set from Jeg's, but they do'nt make them in yellow anymore...gotta call Accel Brake lines don;t look rite
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-31-2008 at 12:17 PM. |
10-31-2008, 12:47 PM | #763 |
Re: PO has me PO'd
Awe come on...you're not old!
10-31-2008, 02:30 PM | #764 |
Its lookin' like a Blazer!
Re: PO has me PO'd
Considering what I've got done to mine in the past 3 months I'd call what you've got done major progress, lol......
11-04-2008, 05:56 PM | #765 |
Re: PO has me PO'd
Finally got the oil pan mounted up, one pc. gasket, and grey silicon on all 8 corners(top and bottom of gasket) as recommended by the members
I think this engine is a canidate for Seafoam, coked up... I'll pull the dizzy and make up a shaft to spin the oil pump since I want to prime the entire oil system before starting up the engine
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-04-2008 at 06:03 PM. |
11-04-2008, 07:06 PM | #766 |
Re: PO has me PO'd
Thanks for the inspiration there buddy!
What do ya think about running to Tenn. in July of 09 in our trucks? |
11-04-2008, 07:28 PM | #767 |
Re: PO has me PO'd
Would that be a warm up for the Michigan trip?
11-04-2008, 08:37 PM | #768 | |
Re: PO has me PO'd
Actually, the foe is on the other shoot...you inspire me! Your work is far superior to mine, I would never go where you have gone. Nice job on the Garage, I see many, many happy hours down there
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-04-2008 at 08:42 PM. |
11-04-2008, 08:57 PM | #769 |
Re: PO has me PO'd
Yeah, they sound like a great bunch.
I've met a couple, looking forward to meeting more... Mich. is still a 'must do', this only came to mind when I read they were having a gathering in July next year. Think it's doable for ya Tim? |
11-09-2008, 12:19 PM | #770 |
Re: PO has me PO'd
Nice work!! Great idea on the crossmember. Did the frame rails spread any when you took it out? Or did it bolt right back in?
btw...love the fish pic! |
11-09-2008, 08:08 PM | #771 |
Re: PO has me PO'd
I'll be able to answer your question in a couple days, parts are painted and waiting for reassembly....didn't appear to move much when I took it out
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-09-2008 at 08:09 PM. |
11-13-2008, 04:01 PM | #772 |
Re: PO has me PO'd
OK, woke up at 4 AM this morning figgered I'd put some time into the truck...got the final crossmember in and buttoned up. I suggest starting all bolts and then tighten down, as this seems to pull everything together evenly, This mod could be done at home, but I didn't want to fool with DIY4X's product in case something went wrong...
AJ, didn't see any pulling or pushing of the frame members while I installed it Here's some pics. I picked up some utility seats from 6t727t2 and my plans are to recover them like the pic supplied by Ironmike OK, now I'm back to where I was 2 months ago...lol. Also decided to buy a short block, I'll start searching for the best price, maybe GM remanu
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-14-2008 at 04:53 AM. |
11-14-2008, 07:06 PM | #774 |
Re: PO has me PO'd
Yeah...what he said?
11-14-2008, 07:31 PM | #775 |
Re: PO has me PO'd
Crossmember looks great. Great choice on the interior...looks like mine!
