#35 |
Re: What is your engine setup?
I have a stock internal 5.3 LSx. With this engine I would swap out the cam and maybe adding alittle nitrous for the track.
Down the line I would like to build a 402/408 stroker using a 6.0/6.2 block, 4.00" stroker crankshaft, a lumpy cam, and a decent set of heads (LS3/L92 heads will work).
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
