Old 02-20-2010, 08:17 PM   #126
JPCY72
Re: Autometer Cluster Projects
This is what Im using real wood! A friend made me two one with this vineer and a different vineer on the other one.
JPCY72 is offline   Reply With Quote
Old 02-21-2010, 02:00 AM   #127
Mudder
Mudder's Avatar
You can find the white face 3 3/8 water temp and oil pressure still. Every so often you can find a fuel pressure guage 3 3/8 like above or a tranny temp guage. I have watched for a long time and I haven't seen any fuel guages. I have a 3 3/8 fuel pressure guage extra but I wouldn't mount it inside of a cab.
Mudder is offline   Reply With Quote
Old 02-21-2010, 02:03 AM   #128
djracer
djracer's Avatar
Mudder if that fuel pressure gauge doesn't come with an isolator they do make one. Fuel goes to it then something like antifreeze goes up to the back of the gauge.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-21-2010, 02:09 AM   #129
Mudder
Mudder's Avatar
I didn't know anything about it but just what I read about it. I'm not even sure if it is all there. Shame cause it would sit in that center hole really nice.
Old 02-23-2010, 06:27 PM   #130
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Originally Posted by jackyl9999 View Post
Here is my gauge cluster that I am working on.
Very nice! I'm in the process of doing mine the same way as your's but I'm doinging white faced gauges. What did you use for the 33/8 hole and the turn signal holes?
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-23-2010, 07:35 PM   #131
kev2809
low n' slo
kev2809's Avatar
i dont want to sound like a cheapo..but i was in oreilly the other day and they had some cool reasonably priced gauges in there. they kinda look like this.
would they be worth the money? that one is an autometer gauge i think, like 54 bucks. but i think the others are a bit cheaper.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-23-2010, 09:02 PM   #132
djracer
djracer's Avatar
I would want them all to match each other even if they were different brands.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-24-2010, 01:07 PM   #133
watahyahknow
watahyahknow's Avatar
its to bad you cant take them apart as eazy as a regulair cardash , there a lot of custom skins available for gauges wish would equal them verry nicely
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-24-2010, 02:25 PM   #134
drewdude92
72 chevys 4 life
drewdude92's Avatar
what size of aftermarket gauges fit in our bezels? idk if someone has asked cause i dont have time to look through
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 03-08-2010, 10:38 PM   #135
Camaro_nut2001
Here is mine I just finished. I have Autometer speedometer and tach and the bottom four are Peterbuilt gauges.Name:  new gauge panel.jpg
Old 03-08-2010, 10:40 PM   #136
Camaro_nut2001
I didn't get to use the white faced gauges.
Old 03-10-2010, 03:29 PM   #137
Putter
More Cowbell....
Putter's Avatar
Originally Posted by kgt View Post
Is it rude to ask what something like that costs?....If so i understand. It looks fantastic!!...
Total?
My cluster has somewhere in the neighborhood of $700 in it. New gauges, new bezel, wiring harness parts, etc....
Or labor only?
(please PM me about this, since I am not a vendor). I just do this every now and then.
And....I just happen to have a few (spare) 3-3/8" gauges in the ProComp color scheme (black with white letting). They are (if I remember correctly) oil temp gauges. Now these are identical to Water temp....even down to the sending unit. Same thread pitch, same sensor bulb, etc... The only difference is the actual word "Oil" instead of "Water". So, technically, I figure you can install it to monitor either.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
