Old 08-21-2011, 12:25 AM   #26
KrazyRay
KrazyRay's Avatar
Re: Making a trailer from a Pickup
I have built hundreds of these trailers. I personally use a 3/4 ton with coil springs with a hydraulic dumping bed. I have hauled 5000lbs of gravel in it. With a coil spring trailer, you need to have good shocks or it will sway all over the road. For best performance, cut your axle shafts off and bolt the end plates back on. Next, remove your dana 60 3rd member and weld a plate to cover the opening. Add gear oil to keep your hubs lubed. You now have a full floating straight axle. With an eaton axle, you can simply buy an additional pumkin cover and use that to cover the opening instead of having to weld a plate. You can also sell the eaton 3rd member for $100- $150 which will cover all costs to construct the trailer.
KrazyRay is offline   Reply With Quote
Old 08-21-2011, 09:13 AM   #27
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Originally Posted by sleepertruck72 View Post
I dont think you need trailer brakes if the brakes in your truck are in good working condition. It has worked for me with heavy loads no problem (2-3K#) You may as well invest in a tranny cooler if you dont have one already, or new brake pads for your truck etc. As for the diff, I would drain it out, replace gasket and refill.. Just my 2 cents
Here's a pic of mine.. very similar color to yours
Nice rig, I was thinking of adding a ladder rack like that too. My tongue is longer though to help with backing up and also to clear my larger toolbox when backing up sharply, have more room when getting things into back of SUV, ect. Also a little more stable at speed on the road.
No brakes won't be an issue when pulling this with the 2500hd but I will be pulling this on occasion with my honda Pilot and lets face it, its not a real truck and could benefit from brakes, especially with the traffic in the minneapolis area. This trailer has new brake lines and non rusty parts. I bolted on a standard coupler for now and will see how she works before buying a hydraulic actuator.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 08-21-2011, 09:20 AM   #28
Vintage Windmills
Vintage 4x4s
What holds the axle ends if you cut part of them? Why not just remove? Also if the axles are not turning the gears why bother removing the pinion gear shaft? Good to know on the Eaton cover. If you have an extra I'd be interested. I plan on building a second trailer from an Eaton coil springC20.
Got the wiring hooked up. Sure is easy to use the original lights and they are nice! Now if I could incoorporate the backup lights that would be awesome.
Also tempted to hook up a hand parking brake on the tongue and use the parking brake feature too. I know some will say don't bother but why not if they are in good shape and stay that way since I won't use this in the winter and salt them up.
Old 08-21-2011, 10:46 AM   #29
KrazyRay
KrazyRay's Avatar
The axle end plate is part of the axle shafts. I just cut the shafts right by the plate and bolt the plate back on to seal the axle housing. I remove the eaton 3rd member for the purpose of selling the parts. I guess you can leave the pinion on a dana since it does not have much value for parts. If you step up to a 7 pole connector, you can use your reverse lights. I did that on my trailer because I needed the extra wires for the hydraulic dump. A member in Grass Valley, CA uses the 67-68 parking break for his trailer. I have not bothered to because I'm on flat ground; he lives up in the mountains. There are some old threads about these trailers and he has a pic of his e brake setup.
Old 09-29-2011, 01:55 PM   #30
Vintage Windmills
Vintage 4x4s
Thanks guys for the advice. I got it on the road and works great. I replaced the tailgate, rear bumper. I also redid the shocks and aired up the tires so it rides better than my standard 9' utility trailer now. The longer tongue makes it stable and ride better. Also removed the axles, redid the gaskets and put fresh gear lube in. Just need to straighten out the tailight area, mount the truck toolbox on front, and prime and paint everything. Oh, and maybe wire in the backup lights.
Got about 300 in parts it so far but Its capable of high speed cross country hauling heavy loads. Not too shabby if you ask me.
Old 10-02-2011, 09:15 AM   #31
CG
BlahBlahBlah
That looks great. I don't know enough about rear ends to totally get what you did. Guess Ill look at a parts break down of one so I can figure it out.
I'd really like to know the specifics about where you did your bends, how long is that extra bar you welded in for the tongue? Just a little more detail when you have a minute.
Old 10-02-2011, 10:36 AM   #32
Boog
laying low
Boog's Avatar
CG here's a link to building a truck bed trailer I ran across. Looks like a solid deal to me. Of course there are a number of ways to build the tongue.
I am saving a 97 truck to do just this with.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-02-2011, 06:37 PM   #33
sleepertruck72
sleepertruck72's Avatar
Nice job on the trailer... looks like that puppy is heavier than the mulch With a toolbox and a rack for lumber, etc. these trailers are awesome !!!
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 10-02-2011, 09:47 PM   #34
too much stuff
Roadtrip!
too much stuff's Avatar
Now if you would just fix those tail light and back up lenses you will be set!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-04-2011, 02:17 PM   #35
Vintage Windmills
Vintage 4x4s
Eric, A nice guy stopped by on Saturday and helped me pull out the dents around the tailights
He is a little over 100lbs now so it must have been close! And he's still in the process of bulking up for winter I would love to get a nice ladder rack for this. I've got the toolbox, just need to fix latch and mount to frame.
I didn't get the rear end thing either until I tore it apart. Basically, on the Dana 60 8 lug, the axle shaft has the end plate that is on the outside of the hub. So, you take those bolts out and the axle comes out. You then cut the end plate off, and bolt it back on. This way, you remove the axle but retain the original end plate. You don't even have to take the wheel or hub off. This is because the bearings are on the outside of the axle tube between it and the hub.
I'll take some measurements on the bends and let you know. I don't know if its the best way, I just know it was pretty easy and this pulls great with no sway or hopping but I did put new shocks on also.
Old 10-04-2011, 08:06 PM   #36
69C-owner
Wondering now if I should remove the axles from the Dana 60 so it doesn't have to spin them?
Take the easy route and just leave the rearend alone, tearing into it u will cause lube problems for the axel bearings and end up with a locked up wheel on the side of the road
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 10-08-2011, 11:33 PM   #37
Vintage Windmills
Vintage 4x4s
I took some pics today of the way I did it. Like Ray, I notched the frame and allowed the top and bottom rails to overlap a little so its a lap joint instead of a butt joint.
I'm going to do the permanent wiring with some cord that runs through the rectangular tube tongue.
Old 10-08-2011, 11:37 PM   #38
Vintage Windmills
Vintage 4x4s
more pics. Tape is measuring from the box bracket edge in the 1st pic below
Old 10-09-2011, 02:12 AM   #39
CG
BlahBlahBlah
Thanks for the extra pics and info!
Mark
Old 10-09-2011, 06:18 AM   #40
mcmlxix
Collector of Projects
mcmlxix's Avatar
I picked up one of these long bed coil spring trailers... I just registered it on Friday. The guy I bought it from overloaded it and broke the panhard bar and the spring retaining plate... I hope to fix those two isses next week. I just need to find some tires....
Rich
1972 K5 Blazer CST Click HERE
Old 10-09-2011, 07:00 AM   #41
68 SHORT-STEP'N
SLOW POKE
68 SHORT-STEP'N's Avatar
Fine looking trailer you made there V W . Has anybody done this with a short-stepside bed w/o the extra room for a toolbox ? Also someone mentioned a " how to " link . I would hate to cut my frame too short . Thanks !
68 SHORT-BED-STEP-SIDE
piece by piece ,
day by day ,
I will restore this truck ,
before the 100th anniversary !!!
68 SHORT-STEP'N is offline   Reply With Quote
Old 10-09-2011, 11:08 AM   #42
Boog
laying low
Boog's Avatar
I think that was me. I should have gone back and put this in later. While V W's looks good there are several ways of going about it. I found this one some time back and liked it. Cannot deny it's strong.
And yes trailers have been made using short stepside beds. There is a member here with a real nice green one although i cannot remember his name at the moment. Maybe he'll see this and post it up for you.
http://sweptline.com/blog/2009/01/20...-pickup-truck/
Boog
primer is finer
Old 11-01-2011, 10:04 PM   #43
cool1972gmc truck
how do you license these trailers??? i have one made out of a 1970's ford pickup and im not sure how to register and license these. I live in colorado if that makes a difference.
cool1972gmc truck is offline   Reply With Quote
Old 11-01-2011, 10:44 PM   #44
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Ya mean one of these?
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-01-2011, 11:00 PM   #45
CG
BlahBlahBlah
I know its easier to maneuver with a longer tongue, but it seems if you get it too long you are going to lose stability without enough weight on the tongue. Trailer could get pretty squirrely back there.
Old 11-02-2011, 08:36 AM   #46
Vintage Windmills
Vintage 4x4s
Minnesota doesn't do anything special for these and they don't care about the Vin on there either. They had me register this with the standard utility trailer (less than 3500lbs) lifetime permanent registration. Your state may be different but it is pretty simple here, the only thing I had to submit was a form stating components and value of them so they could tax it appropriately Its nice I don't have to ever buy tabs or pay again though.
