Parting out 69 C20 PRICES LOWERED!!!
Got what's left of a '69 C20 to part out. Cab and bed sheet metal was junk, so that's gone to scrap metal. Here's what I have off so far:
Headlight trim, straight light surface rust sold Fender emblems, some over spray, easily cleanable SOLD Front turn signals with lenses sold Gauge cluster, nice printed circuit, everything works SOLD 4 row radiator clamps, rubber good. sold Headlight buckets with springs and adjusters sold Tailgate trunions 10.00 shipped Ball bearing ashtray, crappy paint job, but works great! 10.00 shipped Lighter, headlight switch, and wiper switch with knobs, headlight switch looks fairly new. tiny bit of over spray on lighter trim that will clean right off. All in working condition SOLD Hood latch with support. Nice and straight, works fine 25.00 shipped Brake booster w/ proportioning valve and master cylinder. For drum brakes, works fine. SOLD High hump trans tunnel. Very nice!!! With bolts SOLD Saddle seat belts, needs cleaning, pitting on chrome on 1. 1 buckle has a little cracking SOLD Saddle visors, very nice SOLD Aqua blue/ green visors, very nice SOLD Chrome 1 wire alternator, working condition, don't know the amperage. dsSOLD 4 row radiator. Aftermarket, appears to be recently replaced. Fins are perfect. Very nice. SOLD Left fender, very clean, no dents, cup is good. PO screwed front molding in with 2 small screws, otherwise really nice shape SOLD Right fender, same screw holes, but 4 instead of 2. Cup has rust, but the rest is very nice. SOLD I'll be adding more as I get it apart. If you don't see it, ask, I might have it!!
'67 C20 LBW Last edited by ScottG; 11-27-2012 at 01:30 PM. Reason: MARK SOLD |
Roadtrip!
![]() Join Date: Feb 2003
Re: Parting out 69 C20
I will take the emblems if the studs are intact.
Engine stands?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#3 | |
pm sent on the emblems. thanks, Scott
'67 C20 LBW |
![]() Join Date: Mar 2012
i'll take brake booster
![]() Join Date: Jun 2011
I need the part of the floor where the high hump cover bolt to if you still have the cab ?
![]() Join Date: Jan 2012
Interested in the lighter and switch set. Do you have the wiring harness for the lighter? Is the headlight switch a gm part?
Posted via Mobile Device |
'67 C20 LBW |
I do have the harness, I'll throw that in. Switch looks aftermarket, but that's not a bad thing. Put 2 Delco switches in my truck, 1 took a dump after 2 months, and the replacement was DOA right out of the box!
'67 C20 LBW |
No sorry. I cut it up because it was badly rusted. I'll keep an eye out though.
'67 C20 LBW |
I'll take the seat belts. PM me your payment info.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
'67 C20 LBW |
Hey scottg I was mostly concerned with the knobs looking the same including the brushed metal inserts. Do they? Would all the parts clean up real nice? Does the lighter assembly have a light? Just curious. Thanks
All knobs are identical, they will clean up nicely. Lighter does not have a light.
'67 C20 LBW |
#15 |
'67 C20 LBW |
#16 |
I'm looking for a bellhousing #3925505
#17 |
I will take the cluster. PM me with payment info
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44 1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt General Motors Master Certified wrench swinger ASE certified Master auto tech Instructor of Automotive Technology |
#18 |
Active Member
![]() Join Date: Oct 2002
Do you still have the big block power steering hose
#19 |
I have one, but not sure of the #. I'll check when I get home.
'67 C20 LBW |
#20 |
PM sent. Thanks, Scott.
'67 C20 LBW |
#21 |
You know, I might. The p/s bracket doesn't look right to me for a small block, so the PO might have used the original on it. I'll get back to you on this.
'67 C20 LBW |
#22 |
Paypal sent. Thanks
#23 |
Hey Scott, I'll take the lighter w/harness and switches. PM me with payment info. Thanks
#24 |
Thanks Scott, I need the 5 inch opening, not the 4.xx inch opening.
#25 |
PM sent, thanks!
'67 C20 LBW |
Tags |
cluster, fenders, radiator, seat belts, visors |
