01-10-2013, 08:50 PM | #1 |
What kinda carb is this?
Is this a double pumper or just a single, also one of the main numbers I got off of it is"6R-4237B" Posted via Mobile Device
71 c10 swb |
01-10-2013, 09:06 PM | #2 |
Re: What kinda carb is this?
2 bowls, double pumper
holley Qjet design |
01-10-2013, 09:09 PM | #3 |
If I have it rebuilt would it be alright to put on a stock 350? I'm not sure what cfm it is.
71 c10 swb |
01-10-2013, 09:20 PM | #4 |
Ok after searching a little more I found it was a 650cfm qjet replacement for 327-400 motors. Good deal I'm going to get it rebuilt now!
71 c10 swb |
01-10-2013, 10:24 PM | #5 |
If I swapped out intakes which would be best for the holley?
71 c10 swb |
01-10-2013, 10:46 PM | #6 |
If it is a replacement for a Q-jet it will be a spead bore type carb. It will work best with an Edelbrock Performer manifold or other spread bore manifolds. There is not enough photos to tell but it probably is not a double pumper.
01-11-2013, 12:38 AM | #7 |
It is a spreadbore and a double pumper for sure, you have an accelerator pump on both the primaries and secondaries. I could be wrong but it looks like you are missing some screws on the base plate.
01-11-2013, 01:07 AM | #8 | |
71 c10 swb |
01-11-2013, 01:16 AM | #9 |
That old n crusty, id want a pro shop rebuild, not just toss a kit in it.
01-11-2013, 01:41 AM | #10 |
60-66 Nut
You need the list number off of the choke horn. It's probably a 6210
01-11-2013, 02:24 AM | #11 |
My Carbon Footprint
He's not missing any screws.....he just has 2 in the wrong spot. The 2 center ones should be moved up/down depending on how you look at it. The center holes are left open from the factory.
01-11-2013, 01:14 PM | #12 | |
71 c10 swb |
01-11-2013, 02:14 PM | #13 |
My Carbon Footprint
Correct and I'm not sure I will EVER understand why Holley machines the main body for screws and the base plate has the holes for them and yet they don't come with them.
01-12-2013, 01:33 AM | #14 |
Dino burner
01-12-2013, 09:04 AM | #15 |
My Carbon Footprint
You have a 50% chance of getting the cfm guess right since they only made 2 Holley spread bore CFM sizes. A 650 and an 800. 800's are super easy to spot because they have huge rear boosters.
01-12-2013, 05:07 PM | #16 | ||
"I ain't nobody, dork."
I always loved the look of those big rocket boosters...
Gary
01-12-2013, 06:18 PM | #17 |
My Carbon Footprint
They are so high in the venturi that you would think the signal would flat suck!
01-13-2013, 01:42 PM | #18 | |
71 c10 swb |
01-13-2013, 02:07 PM | #19 |
My Carbon Footprint
Interesting how that little Holley wound-up with those super old needle and seats. The carb can't be all that old because of the plastic vac housing top.
01-13-2013, 08:41 PM | #20 | ||
The 1850 on my Dad's 355 has the old style bowls with adjustable floats/needle and seats. Also has the metal vac housing too. I didn't like it when Holley switched the 1850's over to non-adjustable floats.
Gary
01-13-2013, 08:49 PM | #21 |
My Carbon Footprint
Yes but those needles use an O ring to seal and once you crack them loose, it's very hard to get them to not leak.
01-13-2013, 09:38 PM | #22 | |
No No
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
01-13-2013, 10:18 PM | #23 |
My Carbon Footprint
I'm pretty sure he knows that. I think he was just stating the facts.....it has 2 fuel bowls and is a double pumper. ;o)
01-13-2013, 10:21 PM | #24 |
The numbers on the choke horn are 6210-3. Where can I find a rebuild kit for it?
71 c10 swb |
01-13-2013, 10:48 PM | #25 |
Hollister Road Co.
I have one of those on mine and i was hoping it would be better than a QJet. Its been nothing but trouble and after some research I have found that its the worst of both Holley and Qjet carbs combined. It has minimal adjustment to make it run correctly. It boils over without a phenolic spacer, The floats hang often and flood out the engine, I'm going back to a Qjet. I've had to rebuild mine 3 time in 2 years before it finally work half way decent.
