Old 05-10-2013, 09:55 PM   #1
Olive1970
Olive1970's Avatar
Which intake for my truck???
Considering the Edelbrock 2101 or 7104?
http://www.summitracing.com/parts/ed...make/chevrolet
Not sure which one to get, don't want to get too much intake for the engine or too little either. A little about my setup: Chevy 357 4 bolt, eagle rods, SP coated flat-top pistons, 1.94/1.60 heads, upgraded springs. .488/.510" lift cam, MSD HEI ignition, Holley Spreadbore carb (650 cfm), Headman headers, 3" exhaust with hedman x-pipe and flo-pro muffs.
Thanks for all your help! I have had so much trouble with this truck lately im about ready to throw in the towel
Gary
Slowly looking for my next 67-72 truck
Olive1970 is offline   Reply With Quote
Old 05-10-2013, 11:11 PM   #2
Roninwolf
Roninwolf's Avatar
Re: Which intake for my truck???
The RPM will match your cam profile better.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 05-11-2013, 03:38 AM   #3
SS Tim
SS Tim's Avatar
Are you still planning on running 3.07 gears? That is what a 350/th350 70 C10 had as stock.
SS Tim is offline   Reply With Quote
Old 05-11-2013, 04:05 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
First off ditch the Holley spreadbore the whole lot of those should have never been made. Those things are a nightmare
Second. What's your cams duration?
A performer rpm intake seems like the better match so far
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-11-2013, 04:51 AM   #5
Olive1970
Olive1970's Avatar
I am still planning on running them for the time being, if I ever change them.
Gary
Old 05-11-2013, 04:53 AM   #6
Olive1970
Olive1970's Avatar
Are the Holley Spreadbores really that bad? It seems like it runs the best on the truck so far, well for the most part. I also have a Street Avenger 670.
The duration at .050" is 234 244 on the cam.
Gary
Old 05-11-2013, 07:50 AM   #7
wesmigletz
wesmigletz's Avatar
I've had decent luck with the old spread bore double pumpers. The 7104 is a nice intake, too. However, I think your truck will run better/quicker with a sum-1103 or sum-1105 cam, given your converter and gearing.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 05-11-2013, 08:34 AM   #8
cdowns
cdowns's Avatar
if you r running 307 gears and combined with that oversized 3" exhaust you r loosin alot of bottomend torque
Old 05-12-2013, 12:49 PM   #9
Olive1970
Olive1970's Avatar
FYI, I did have 2.5" exhaust on this truck before and it restricted the engine considerably. I have done my homework before putting the 3" exhaust on.
Gary
Old 05-12-2013, 02:03 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
I would suggest the RPM as well.
My experience has been that 2.5" duals are plenty. I would also suggest a lower rear axle ratio if tou want to realize the full potential.
WIDESIDE72 is offline   Reply With Quote
Old 05-12-2013, 02:18 PM   #11
TBONE1964
Cluster King
TBONE1964's Avatar
Gary,
You are asking the right question to the wrong people (no offense to anyone).
Contact the tech department of your cam manufacture and they will ask you some simple questions and recommend an intake that will work best for your combination of parts.
That is what these people do day in and day out. It is easy to say that your exhaust is wrong, your gear is wrong, your converter is wrong, your truck is to heavy, etc... I would love to be able to say to you, "Gary if you use this intake, this is exactly what will happen" but I would only be guessing with your money.
TBONE1964 is offline   Reply With Quote
Old 05-12-2013, 02:31 PM   #12
Fldawg
Fldawg's Avatar
from what you have told us, i would go with the first intake, you want it to work off idle and i doubt your gonna run over 5500 rpm
Fldawg is offline   Reply With Quote
Old 05-12-2013, 02:48 PM   #13
CC69Rat
CC69Rat's Avatar
I'd do the RPM air gap. Your engine sounds like it flows really well for a street engine.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-12-2013, 04:15 PM   #14
WadmalawJoe
WadmalawJoe's Avatar
X2
Toys/projects
Many toys, not enough time to play!
My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!!
WadmalawJoe is offline   Reply With Quote
Old 05-12-2013, 04:31 PM   #15
hayhauler71
hayhauler71's Avatar
Originally Posted by WadmalawJoe View Post
X2
x3
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-12-2013, 04:46 PM   #16
INSIDIOUS '86
That's a fairly healthy cam. Your intake valves are a little small for that the air gap is a good choice or the wieand equivalent which I a little cheaper and has some more low end and very close to the same top end. What's the compression? Some 2.02 fuelie heads will bring some more out on that engine.
As for the spreadbore they work but they were designed as a quadrant replacement and the over size secondary's make for an unstable fuel curve at the top end. Depending on what rpm your turning that engine normally a normal double pumper or vac secondary will give it a good all around feel. The plus side is the spread bore will give a better cylinder fill and response at low rpm
Right now I would lean towards the wieand
Old 05-12-2013, 04:53 PM   #17
CC69Rat
CC69Rat's Avatar
Isn't that one the team G or something like that? Absolutely the Wieand would be great too.
If you go with Edelbrock make sure you get their gaskets and the 'gask-a-sinch' product they sell. Your intake will seal a lot better and not leak oil around the 3/5 and 2/4 ports.
Chad
Old 05-12-2013, 06:14 PM   #18
Olive1970
Olive1970's Avatar
I am not 100% sure on what the compression value is. I have known for awhile that the heads are the shortcoming on this engine, I was going off of what the engine builder suggested but those suggestions have not always worked out. I wish that I could get new heads but it is simply not in the budget for me.
I have an old weiand on there now, but it is leaking (sucking air) so that is part of the reason for replacing it. As far as rpms, I am turning up to 6k with the hammer down. My biggest issue has been a stumble or hesitation when accelerating from a roll, I didnt have it as much with the spreadbore carb as with the street avenger. Granted, I found out the intake was leaking when I pulled the spreadbore off so that has made matters worse. Just not sure which carb I should use either?
Gary
Old 05-12-2013, 06:16 PM   #19
Olive1970
Olive1970's Avatar
I looked at that one also as a possibility. My biggest concern was "outflowing" my current cyl heads?
Gary
Old 05-12-2013, 06:19 PM   #20
Olive1970
Olive1970's Avatar
Originally Posted by TBONE1964 View Post
Gary,
That is a great idea, didn't really think of doing that yet. I should give them a call tomorrow, Thanks!
Gary
Old 05-12-2013, 08:25 PM   #21
CC69Rat
CC69Rat's Avatar
Do you know the casting number on your current cyl heads? .. just the last 3 numbers. Do you have power steering, etc.?
Have you thought about changing over to vortec heads and intake style? Do you know approx compression you have now? 64cc heads would wake that motor up! Dart iron eagle heads might be a middle of the road option for you to get her breathing a little more too.
With gas as expensive as it is and a th350, with a stall I think a 3:07 would do fine. Any more than that you'll blow the tires off ( just my opinion) remember its a truck without a lot of weight back there. I'd save that gearing for the highway / gas mileage.
Change to 700r4.. you'd get that bottom end PLUS the fuel mileage on the highway. (Or a GB od.. same idea)
Just some things to throw out there for you. You have a ton of options. But if you went with the RPM age, you'd have it if you ever changed heads. .. humm.
Chad
Old 05-12-2013, 10:20 PM   #22
72chevyk10
I built it
72chevyk10's Avatar
yall realize the regular performer rpm, and the rpm airgap is exactly the same performance? just the air gap is harder to drive in colder weather...
a standard performer is not much better then stock. the rpm is the one to go with in most applications imo.. cept stockish rebuilds, but even then the rpm will make a bit more power
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 05-13-2013, 12:44 AM   #23
Olive1970
Olive1970's Avatar
I would have to check and see what the casting number is. I know they are 400 SB heads from around 1974. The truck does have power steering and power brakes. I would guess the compression ration to be about 9.5:1 if not a little higher...
I have thought about changing the heads, as it would be a big improvement. It is a project I just don't have the funds for at this time or wanting to get into quite yet.
These are all great suggestions, really appreciate your help and everyone else too!
Gary
Old 05-14-2013, 07:01 PM   #24
Olive1970
Olive1970's Avatar
So would it be better to run the Holley Street Avenger 670 over the Spreadbore 650? I have both. Either way I will have to run a spacer on the carb because of the location of the booster port on a Edelbrock Performer RPM intake.
Gary
