700r4 or not 700r4
Hi folks: good moning from Chula Vista Ca.
I found two transmissions 1993, one on a Chevy Silverado and one on a GMC trucks. But the harness conector are at the right side of the transmission not at the drivers side like it is on the 1990 I have. Also I just notice do not have the tv cable. Is this a trans that can be swap or not. Thanks |
Re: 700r4 or not 700r4
It sounds like a 4l60e. There's no tv cable because the shifts are controlled electronically. It can be swapped with the purchase of a trans shift controller. They don't come cheap though. It's a good transmission, just pricey and more often used for fuel injection setups.
Thank you Lefty: Yes I just found in this picture I took, there is no tv cable
http://i962.photobucket.com/albums/a...MG_02051-1.jpg |
Definitely a 4l60e
It's not an option unless you want to add a controller plus rig the sensors to make it work.
OK thanks for your help I will continue with the 90 I already have.
does anyone know if all 700r4's have provisions for a mechanical speedometer?
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
It can be installed on any of them although all the late ones came with VSS
awesome, thanks!
Anyways: I already install the 700r4 but if is possible swap a 4L60E, I want to know what to do and what I had to buy in order to do this swap in a future. I could start to collect all the necessary parts for the next time.
I look for "trans shift controller" and the prices start on 6 hunfred.
yea its not cheap to do electronic transmission without an ECU. i guess the market isnt big enough that the prices have come down on stand alone transmision controllers. Probably wont since most people are going to fuel injection with ECUs anyway. nothing wrong with a good 700r4 .
#12 | |
