Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 09-17-2014, 10:11 AM   #1
'65 chevy lover
WTB Motor Mounts
WTB motor mounts for '73 - '86 C20/30 truck or, '87 - 91 R2500/3500 truck
Thanks,
Billy
'65 chevy lover is offline   Reply With Quote
Old 09-20-2014, 09:59 AM   #2
KrazyRay
KrazyRay's Avatar
Re: WTB Motor Mounts
Do you need the frame towers or just the mounts? Small block or big block?
KrazyRay is offline   Reply With Quote
Old 09-20-2014, 05:17 PM   #3
'65 chevy lover
Thanks for the reply. I need the frame towers. I can easily get the mounts that attach to the block...it's a small block 383 stroker
Old 09-20-2014, 06:16 PM   #4
Speeding Dakota
Speeding Dakota's Avatar
Are the towers different from 1500 & 2500? I thought the difference was the motor mount itself. I have a set or towers out of a R1500 suburban - usually sell them for $25 local if your Interested.
Speeding Dakota is offline   Reply With Quote
Old 09-20-2014, 07:16 PM   #5
'65 chevy lover
I really don't know. Can you post a pic of them? Captain Fab has been helping me with info about what will work. He said that frame mounts from '73 -'87 c20/30 or, '87 - '91 R2500/3500 would work. Otherwise, I don't really know. If you can e-mail me a pic, I'll post it and ask Captain about it.
Thank you!
Old 09-20-2014, 07:37 PM   #6
396ci
396ci's Avatar
fyi, the 1/2 ton towers are slighter shorter as the 3/4-1 ton frames are taller. i have a set for your truck for $38 shipped if your interested. here is a pic..
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 09-20-2014, 08:33 PM   #7
'65 chevy lover
Don't think those will work for the engine mounts I plan to use. This is a link to the engine mounts I was planning to use and, understand will be the best ones for a higher HP motor. Motor I have is 450hp
http://www.summitracing.com/parts/pt...4-bl/overview/
Old 09-22-2014, 07:20 PM   #8
Speeding Dakota
Thank you!
Here are pictures of the ones I have
Old 10-14-2014, 03:08 PM   #9
lowlyfec10
i need to know if the towers are diff between 2wd and 4wd also.....looking for some for my 69 c10 for the ls swap.
lowlyfec10 is offline   Reply With Quote
Old 10-20-2014, 03:26 AM   #10
gearjammer80
'65 chevy lover, Those engine mounts are for the "pre 73" frame mounts.
lowlyfec10, what are you needing them for a 2wd or 4wd
gearjammer80 is offline   Reply With Quote
Old 07-30-2015, 07:03 PM   #11
bulldozer1979
These summit mounts will never bolt into a pickup truck correctly or even at all, the factory setup is bullet proof and thats the route you should go.
bulldozer1979 is offline   Reply With Quote
