09-17-2014, 10:11 AM | #1 |
WTB Motor Mounts
WTB motor mounts for '73 - '86 C20/30 truck or, '87 - 91 R2500/3500 truck
Thanks, Billy |
09-20-2014, 09:59 AM | #2 |
Re: WTB Motor Mounts
Do you need the frame towers or just the mounts? Small block or big block?
09-20-2014, 05:17 PM | #3 |
Thanks for the reply. I need the frame towers. I can easily get the mounts that attach to the block...it's a small block 383 stroker
09-20-2014, 06:16 PM | #4 |
Are the towers different from 1500 & 2500? I thought the difference was the motor mount itself. I have a set or towers out of a R1500 suburban - usually sell them for $25 local if your Interested.
09-20-2014, 07:16 PM | #5 |
I really don't know. Can you post a pic of them? Captain Fab has been helping me with info about what will work. He said that frame mounts from '73 -'87 c20/30 or, '87 - '91 R2500/3500 would work. Otherwise, I don't really know. If you can e-mail me a pic, I'll post it and ask Captain about it.
Thank you! |
09-20-2014, 07:37 PM | #6 |
fyi, the 1/2 ton towers are slighter shorter as the 3/4-1 ton frames are taller. i have a set for your truck for $38 shipped if your interested. here is a pic..
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
09-20-2014, 08:33 PM | #7 |
Don't think those will work for the engine mounts I plan to use. This is a link to the engine mounts I was planning to use and, understand will be the best ones for a higher HP motor. Motor I have is 450hp
http://www.summitracing.com/parts/pt...4-bl/overview/ |
09-22-2014, 07:20 PM | #8 | |
10-14-2014, 03:08 PM | #9 |
i need to know if the towers are diff between 2wd and 4wd also.....looking for some for my 69 c10 for the ls swap.
10-20-2014, 03:26 AM | #10 |
'65 chevy lover, Those engine mounts are for the "pre 73" frame mounts.
lowlyfec10, what are you needing them for a 2wd or 4wd |
07-30-2015, 07:03 PM | #11 | |
