Old 01-03-2015, 05:16 PM   #26
Micmac
Micmac's Avatar
Re: I'm COLD. NEED HEAT. GOING MAD
Originally Posted by KJSR View Post
Thanks man. I have had the best fishing of my life living up here! I guess that's to be expected growing up in SoCal.
I've trout fished (and salmon) all over the world, and I will got there again!
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 01-03-2015, 06:52 PM   #27
edub981
Check out ecklers.com they have a great sale on a heater core til 5th of Jan. I ordered one for 10 bucks. It is alum but can't beat under 20 bucks shipped.
edub981 is offline   Reply With Quote
Old 01-03-2015, 08:52 PM   #28
CRGRS 66
CRGRS 66's Avatar
Originally Posted by trevota View Post
also if your truck over heats when it shouldnt ( like with a 195 t stat in 20 deg weather), then i would check for a possible water pump problem, or i have seen bad head gaskets/ cracked heads cause no cab heat and over heating. The cooling system pressurizes and that can restrict flow. That usually also has other sytpoms like leaks etc
My 65 with basic heater is rarely off of first or second fan speed cause the cab is so hot
water pump may be an issue that would prudent to diagnose, as you state with the 195 tstat you are running hotter than you are comfortable running, and yet you are not getting enough heat in the cab
Originally Posted by Figuarus View Post
The basic air box does not have a controllable flap to direct air. The only heat on/off is a flap in the plenum that closes and doesn't allow heat to be directed into the cab. The true heat on/off option heaters had a valve inline with the 5/8ths hose and had a cable that opened and closed it.
I'm going to swap out the core later today, and if it's not a significant improvement, I will end up modifying the box to allow air to be pulled in from around the passenger side exhaust manifold.
All that waste heat has to be good for SOMETHING, right?
KJSR, I will call you up sometime this next week, or next weekend.
thanks for the offer!
IMHO that trying to capture heat from the exhaust manifold would A) not be practical
, B) may capture more cold air in the process anyway, and most importantly C) if the problem is the water pump, or some other cooling system component, modifying the heater box would be redundant.
Let us know what the result is of changing the heater core.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 01-03-2015, 09:05 PM   #29
americanmusc1e
americanmusc1e's Avatar
I got a radiator core from autozone a couple of years ago (2008??) and it was a copper core.. Not sure if they still have them or not. also mine was with A/C.
My project has the heater off of the firewall (there is a giant hole there now) and electric radiator fans. Driving it around so far I have to crack the windows in 40* weather when i have the fans on because there is so much warm air coming off of the radiator through the firewall
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 01-06-2015, 04:02 PM   #30
Figuarus
Figuarus's Avatar
crgrs, you're absolutely right. I really should get the pump checked. It's at least 11 years old, and the truck did sit for a long while. I'll have to get a pump installed in the next few weeks.
I've been sick, and still haven't gotten the heater core installed, but I will hopefully do that in the next few days. (head colds suck...)
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 01-06-2015, 04:10 PM   #31
Micmac
Micmac's Avatar
Hope you get to feeling better, bad flu out this way , no Zombie sitings yet! 8 people dead from the flu in NC.
Old 01-06-2015, 05:45 PM   #32
Figuarus
Figuarus's Avatar
Wow, that sucks. Lets pray it's not Captain Tripps...
2013 Malibu LTZ
Old 01-06-2015, 06:20 PM   #33
vince1
My truck was a home to gophers for many years. They had completely taken all the seat material apart and packed it into the heater ducting all the way into the heater box and fan. I cleaned it all up and put in new ducting. Can't say the heat is that good though. Certainly not quite as good as in other vehicles I've had of the same vintage but still tolerable. Also the heat control levers were off or broken so had to get those working. Do your levers work and is it blowing lots of air where it is asked for?
vince1 is offline   Reply With Quote
Old 01-06-2015, 06:43 PM   #34
Figuarus
Figuarus's Avatar
vince,
I pulled the airbox apart, cleaned it, cleaned the core, replaced the blower motor, cleaned the plenum box, and made sure the two flaps both work. I can select between windshield defrost, and floor. The hot/cold flap works. The only issue here is not enough heat coming from the airbox. Don't get me wrong, It's relatively warm, just not warm enough. I get 50 degree air when the temp outside is about 40.
I have to run the truck for about 15 minutes to get the coolant warm, and then turn on the fan to get any effect out of the windshield defroster.
2013 Malibu LTZ
Old 01-06-2015, 07:30 PM   #35
Bare64
Bare64's Avatar
Like jtrichard said "some pics of how your hoses are ran" from the water pump to the heater box under the hood and back would be good. I had this issue when I was 15 years old with heat in an old Nova, I had put the TStat in upside down causing it to run hot along with no heat. My Dad laughed his ass off at me for a week or so.
Bare64 is offline   Reply With Quote
Old 01-06-2015, 07:35 PM   #36
jtrichard
i asked for pics because i have seen them hooked up totally wrong and NO hot water was going through the core
jtrichard is offline   Reply With Quote
Old 01-06-2015, 07:42 PM   #37
Bare64
Bare64's Avatar
Understand, guilty of that one too in my youth.
Old 01-06-2015, 08:07 PM   #38
CRGRS 66
CRGRS 66's Avatar
I noticed a good question that I don't believe was asked previously...
Vince1 asked if the blower was blowing air where it is asked for. Are you getting strong air flow from the fan?
Still think you need to look at the water pump, but just wanted to clarify that the fan is blowing ample air.
Craigerrr
Old 01-06-2015, 09:17 PM   #39
Figuarus
Figuarus's Avatar
Yes, the blower works very well. I tried posting photos, but i cant seem to get them to upload.
2013 Malibu LTZ
Old 01-07-2015, 03:31 AM   #40
Figuarus
Figuarus's Avatar
Lets see if this works. Posting fro my phone.
2013 Malibu LTZ
Old 01-07-2015, 04:07 AM   #41
Micmac
Micmac's Avatar
Well, I went to post the ones you sent and lo & behold! I'm digging the skull on the air cleaner! The hoses look right to me, but it's 0305 here and 9 degrees, and I ain't going outside to check! My memory ain't what it once was. I think it happened in '69, or it could've been '72?
Old 01-07-2015, 07:11 AM   #42
Coltronist
I had the same problem with my other c10. Once I lit the truck on fire the heat problem went away but I started to have other problems. Fortunately however, my thermostat seems to be working perfectly!!
Coltronist is offline   Reply With Quote
Old 01-07-2015, 10:24 AM   #43
Figuarus
Figuarus's Avatar
You know what they say; light a fire for a man, he'll be warm for a night. Light a man on fire, he'll be warm for the rest of his life.
2013 Malibu LTZ
Old 01-07-2015, 11:20 AM   #44
Figuarus
Figuarus's Avatar
Yeah, i tried posting them again after I sent them to you, and lo an behold, I was able to do them from my phone this time.
That skull was painted about 15 years ago, when I was 15, and was originally done for my dad's Monte carlo. His carb and transmission found their way into my truck, so I figured it to be only proper to clean it up and put it on my truck.
Here's a better view of it.
2013 Malibu LTZ
Last edited by Figuarus; 01-07-2015 at 11:22 AM. Reason: I cannot word this early in the morning
Old 01-07-2015, 11:57 AM   #45
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Hoses look correct. On the 3/4" hose, when the truck is at operating temp, is this hose the same temp as the upper radiator hose? They should feel the same, almost too hot to touch. If they are, does the 5/8" hose feel only slightly cooler or does it seem a lot colder? This will tell you if you are getting heat in and out of the lines.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-07-2015, 12:39 PM   #46
Figuarus
Figuarus's Avatar
the 3/4 definitely gets hot, and isn't QUITE as hot as the radiator hose, but it's pretty damn hot. (I have a metal flex hose on the upper line @ the radiator.)
2013 Malibu LTZ
Old 01-09-2015, 04:25 PM   #47
Figuarus
Figuarus's Avatar
Ok, i pulled the core, inspected it, cleaned it out and re-installed it. Same issue.
Someone mentioned water pump, but i got to thinking that if the water pump was bad, I would be overheating, but have no flow to the core.
I'm leaning towards a restriction, but I don't think it's in the core. I'm wondering if there is something at the pump itself, or in the manifold.
2013 Malibu LTZ
Old 01-09-2015, 06:23 PM   #48
Bare64
Bare64's Avatar
Make sure you TStat was not installed ass-backwards.......big restriction
1964 Bare to the Bones
Old 01-09-2015, 08:19 PM   #49
mr andrerson
dissimilar metals tend to cause fierce corrosion. maybe the nipple n tee coming off the water pump are restricted? could you take the hose off and shove a screwdriver in there to see if it is clear?
mr andrerson is offline   Reply With Quote
Old 01-09-2015, 08:53 PM   #50
awbrown
there a few ways to positively identify what is wrong .. first , it looks like you have your hoses right , second once it is fully warmed up , you should feel both sides of the heater core where they go into the core ,if both are not scorchin hot , then it is your heater core , if one is cooler , then you can be sure your core is plugged....
awbrown is offline   Reply With Quote
blower, core, heater, heating, radiator
